Question about Exercise & Fitness
E1 error on JS-4500 treadmill - Exercise & Fitness
  • 33 Answers
SOURCE: I have a BH treadmill that has an E1 Error messgae...
Your problem might be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
  • 33 Answers
SOURCE: E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
  • 33 Answers
SOURCE: Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
Treadmill triumph 400t has error E1
E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
It is very unlikely the ordinary Jo Blo can fix this problem.
Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
May 17, 2010 | Exercise & Fitness
E1 code
Your problem might be that a magnet has fallen off within the treadmill. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Apr 28, 2010 | Tunturi T30 Programmable Treadmill
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
E1 error code
Good luck.
Jun 20, 2009 | Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
Exercise & Fitness Logo
48 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
