DISH Network IR Remote Control Logo
L Jones Posted on Jan 04, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Should tv 1 out setting be on off - DISH Network IR Remote Control
  • Official Brand Answer 263 Answers
  • Posted on Jan 08, 2013
dish
Level 0:
Answers
263
Questions
0
Helped
108328
Points
330
L Jones,
The TV 1 Out setting is based on how your main TV is connected. If you are using a Coax cable to connect to your TV, you will need to enable that. If you're using AV cables, then it can be off. That setting just tells our receiver to broadcast a signal through the coax port. Let me know if you have any other questions!
Tommy Faust
DISH Social Media Representative
Codes for element tv for vibe remote
1. On the remote control, press TV once.
2. Press and hold SET until the LED blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
What are the 3 digit codes for Huayu HR-N99? For samsung. I lost my copy. Please help!!
Input code set method
1, turn on the TV power supply, will be the normal play of the TV set, find out from the code table to the corresponding code by the remote control of TV brand.
2, hold the "set" button on the remote control, until the work light is lit up, let go of "set" key.
3, I just find a set of three digits code. Light is put out.
4, check the validity of other buttons, the effective set, invalid, repeat steps 1-3.
Search code sets method
1, let the normal play of the TV set, will be on the TV remote control.
2, hold the "set" button on the remote control, until after the work light is lit up.
3, of the press "volume +" key.
4, when the volume of symbol to appear on the TV, press the "set" button, the light is put out.
5, check the other remote control button is valid. If the button is valid, set up successfully, if invalid need to repeat step 2-4, until find the code that suits your TV set.
http://www.huayu.cc/EN/_XinWenZhongXin_v283.aspx
Where can I find the list of four digit codes for a vibe axcess 5 n 1 remote
Trying to set up digital set top box to our old LG tv model no CF-21F80KX . Have red white and yellow on set top box and 2 white and 2 yellow on back of tv. Kerrie
The RED and White RCA jacks on the set top box are for Right and Left channel audio to go into the TV Video 1 or Video 2 input jacks of the TV. The Yellow jack is for the Video, that will go into the Yellow jack on the TV Video 1 or Video 2. If you want to use Video 1 INPUT, then all 3 jacks (RED, WHITE, YELLOW) will be use. Just match the color, they should be grouped together per each set of input on the TV.
I hope I explain it well enough.
Its say no signal on tv whats at fault tv or areil
You must have the wrong setting on the set. you will have Ant 1 Video 1 HDMI 1.2.3.check the settings. or RF input behind the set.
10helpful
2answers
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Iwant to know how to program my rca control tosee the tv. I lost the paper with instructions. Thank you
Presuming its also an RCA TV?
The codes are anyone of these
0 0 4 7 ,0 7 4 7 ,1 0 4 7 ,1 1 4 7 ,1 2 4 7 ,1 3 4 7 ,
1 4 4 7 ,0 0 9 0 ,0 0 5 1 ,0 0 9 3 ,0 0 1 9 ,0 6 7 9
PRESS TV SET and light comes on enter code light goes out press SET try turning TV on or off.
Please rate our help++++Thanks for using FIXYA
Can't adjust TV from 1/200
maximum flash sync at 1/200 sec
take the flash out and you should be able to go beyond yet. It is in the manual regarding TV
Have Fun - KD
Top DISH Network Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
