Question about RCA Televison & Video
Vrtical problem I ned the vertical output number chassis m134c
    Top Expert:
  • RCA Master
  • 74,118 Answers
What is the problem you faces with this TV? Vertical rolling? Vertical jitter? Provide more details please.
Posted on Jan 04, 2013
4 Suggested Answers
ttech
  • 139 Answers
SOURCE: Sanyo DS25390 Vertical problem
Jack,Did the Vert Ic have Broken conns around the legs?
Posted on Jul 19, 2007
  • 29 Answers
SOURCE: RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Posted on Jan 16, 2008
ohms
  • 1879 Answers
SOURCE: rcaflat screen m134c chassis
Greetings,
Turn the TV OFF
Remove the batteries from the remote
Turn ON the TV
If the issue still persists, check the channel-changer buttons on the TV
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
AKAI Colour Television CT-1419A/AT plus AKAI remote RC-V9A. Television was fine, then went to just a narrow, bright horizontal band across the screen but sound is fine. Suspect my son played with the...
hi,
Its not problem with any setting. Its an internal fault. Vertical scanning output stage has failed in your tv. You have to check the soldering of the vrtical output ic if there is any dry soldering this can happen. try to resoder all the points in the vrtical output stage. IF doesn't help then you have to change the vertical output ic. Have added the picture of the dry soldering point how it looks like. If you need further assistance feel free to contact throug FixYa.
Aug 20, 2011 | Akai Televison & Video
Vertical failure on this chassis. what is the part # for the replacement Vertical Amp IC. And do you recomend changing any of the capacitors on the output lines?
This unit is listed in the flat panel section. If it is indeed a flat panel TV it doesn't have a vertical output IC. If it is a crt type you need the brand, and exact model number to have any hope of getting a part number.
Apr 12, 2010 | Televison & Video
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
T.V.
Valerie,
That is a M134C chassis - one of the most inexpensive (throw-away) chassis ever built and the so-called v-chip is actaully a function of the micro, short for micro controller Ic. It would be less expensive to replace the entire board, RCA p/n# 268733 which is around $70.00 bucks plus shipping, than to replace just the micro.
You can find them available at Vance Baldwin... Just login as guest and enter thr RCA part number above and order it there.
Putting in an entire chassis is a plug-n-play repair...
Hope this helps.
Bill
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
Weird TV
the audio is perfect, but the screen vertically squeezes to about a quarter of an inch and stays horizontally regular. it is due to vertical section of your tv has failed. it is a common problem if you are not a tech person call tech to fix it. solution 1 check vertical section supply. 2 check components in vrtical output stage. 3 check vertical output ic. 4 loose contact in vertical section it is not a major ptoblem. good luck.
Oct 06, 2007 | Panasonic CT25G7 25" TV
Insufficient vertical height
1 it is due to electrolytic capacitor defective in vrtical output stage. 2 loose contact in vertical. 3 fault due to feedback ckt in v/stage. as per schematic diagram is concern check www.serviceinfo.com
Sep 28, 2007 | Televison & Video
Red Line across Screen
sounds like you have a vertical sweep problem. Where the fault lies cpuld be the vertical output IC the verticle b+ feed, could be the capacitors in the vertical circuit?? Your gonna need to troubleshoot thr vrtical circuit if your not a tech thin my advise is to take the set to a pro for sn est. Good Luck
May 22, 2006 | Hitachi 36UX01S 36" TV
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
