Question about Air Tools & Compressors
Manual for Ward Compressor #XER 6408
Air compressor #XER 6405 S/N 09179-341891 30 years old
SOURCE: Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
Posted on Nov 26, 2008
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
  • 1388 Answers
SOURCE: Manual for Emglo Air Mate Compressor
Manual for the similar dewalt model is at www.dewalt.com, click on parts & service icon, then enter D55151. Or try clicking here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/5135175-01,D55152,Elec.pdf This Dewalt compressor is one of many versions of the Old Emglo AM78 compressor. There are several other brands built with the exact same design such as the Senco line. For parts list of actual Am78hc4v go to mastertoolrepair.com. If you have questions or problems with this compressor please email, Good luck
Posted on Jan 28, 2009
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
SOURCE: Need a manual for a Coleman Powermate air compressor Model #VP0200608 Elec.
I'm looking for a owners manual for a colman powermate air compeser modle cl0502710
Posted on May 04, 2009
Montgomery ward air compressor model xer-6418b
From where does it leak the oil? Many compressors have oilers to keep lines lubed, so on and so forth... Have you drained the tank recently? If its leaking from the compression head assembly? what ever you do dont let that run dry or it will seize and then you have trash.
Oct 13, 2013 | Refrigerators
Turn ac on doesnt seem like the compressor and outside fan that blows air up ward want to work is the diode or compressor no good
If this is a conventional split system, check for power at the contactor, and secure the power and check the run capacitor
Sep 02, 2013 | Siemens Heating & Cooling
How to lubricate an A/C motor
Hi Ken, The AC unit is lubricated with a special oil designed to be circulated with the refrigerant gas. It is poured into the compressor before gas is pumped in. Regards John
Jul 01, 2012 | Cars & Trucks
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Looking for a manual on general overhaul procedures for an old 1979 Webster dual piston air compressor. One piston gets very hot and compressor is quite noisy (sounds like piston slap maybe?).
I have an old De vilbiss twin cylinder air compressor that got noisy. Pulled the head off and found a lot of dirt piled up on one piston (the unit had a very primitive air filter for many years). Scraped the piston clean and washed out the intake passages. Replaced the old filter with an automotive application filter--the compressor sounds like new again. May you have similar good fortune!
Aug 11, 2010 | Garden
8 year old regrigerator with bad compressor
Make sure it's not your start relay thats attached to the compressor.
Well if you are extremely handy you can purchase a new compressor and install it yourself.
Aug 01, 2009 | Jenn-Air Refrigerators
I JUST HAD A GUY COME OUT HERE AND SAID MY COMPRESSOR WAS BAD, HE SAID I MIGHT AS WELL REPLACE THE WHOLE UNIT CAUSE THERE WAS ONLY $400-600 DIFFERNCE IN REPLACING THE UNIT COMPARED TOT HE COMPRESSOR. THE...
better replace a whole unit,than you have guarantee on whole unit not just on compressor.
And your unit is old 8 years,replace it and you have a new.
It is also my suggestion.
Jul 04, 2009 | Weather King 10AJA4801AH Air Conditioner
Mar 08, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Weather King 10AJA6001AH Air Conditioner with bad compressor
If it is five years old it is either right in or out of warranty a service tech can determine this through the serial number. If not the unit is only a little bit more to replace than the compressor. A replacement compressor is only warrantied for one year verses a unit replacement with five years on the compressor and one year parts and labor.
Oct 04, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
63 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
