Question about Intel D845GVSR Motherboard
No Power At Start Up
My Problem: No signs of start up when on/off power button is pushed. No fans running, motherboard green LED is on.
Dis-connected all drives from motherboard - no change. Dis-connected PSU for test: jumped green to black pins - PSU fan starts & runs normally.
I may be wrong, but it appears that the motherboard died. Before I trash it, I would appreciate a second (or more) opinion. This is an E-Machine T2798 with Intel D845GVSR motherboard.
Best regards, Richard
  • rc_kowal Jan 19, 2009
    Drachnem, I tried all but one of the steps you suggested - still no power. I only have one stick of RAM. Should I try to move this to the other open slot?
    Richard
  • 34 Answers
If there is an issue with a card or memory you can run into this issue, try taking out all but one stick of ram, then see if it boots, then if it doesn't try another stick, and move it around the slots.
Also remove any cards you have installed that you don't need to boot up.
Disconnect any 12v power connectors from the drives too, if it boots up, plug them back in one, by one.
Posted on Jan 19, 2009
  • 52 Answers
Most likely need a mb replaced
Device could not start
what device? is *********** board won't start? Or a hardware doesn't start like ram or your printer
If the problem is your motherboard check all your hardwares and connectors like this:
  1. If the motherboard won't start if you click the power button check the LED(the small light bulb on your motherboard) if its glowing. If not, check the connector of your power supply or check the power supply if its working by looking its fan if revolving.
  2. If you push the button and there's a sign of power but didn't start up that will appear on your screen check the connection of your monitor screen to your desktop computer. If it's connected, remove your RAM from the motherboard and insert it to another memory slot to check if it's broken.
  3. Last, if you push the power button and here 1 short beep but the boot screen didn't appeared from your screen check your graphic card. Remove the graphic card and re-insert it again to its graphic card slot and plug in your monitor connector to it. If it still remain that way, buy a new graphic card.
Aug 01, 2011 | Computers & Internet
Have an Abit IC7 motherboard in a system given to me by a friend. I have two problems in getting the board to boot. 1) One of the brackets that the spring mount uses on the Northbridge chipset fell off...
1) The bracket is a simple push fit one - it just pops in and locks in there when pushed.
2) Simple test (assuming that the processor , video card and the memory have been tested in another motherboard and are good): remove all the disks and try to start it up into the BIOS - if you can't then the problem is in the motherboard. As a last hope reset the BIOS and remove the battery for one hour. If it doesn't starts even after that then the board is dead.
The DVD burner will power up and seek even if it's not connected to anything else - all that it says is that the unit is working normally.
Dec 16, 2010 | Abit IC7 Motherboard
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Green led lights up on motherboard no fans or anything will start
It means there is a flea power on the motherboard, but i suspect the powersupply is faulty since the fans is not working. Try to check the power button led light if it is "amber" if yes, Powersupply needs to be replaced.
Hope this helps.
Feb 19, 2010 | Compaq (253219-002) Motherboard
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Gateway GT1040 will not start
Try shorting the power pins on the Motherborad. (establish contact manual. use screw drivers such that they touch both the pins). The power pins are the one the Start button are connected to. Remove this connection alone. If this powers up the system, you would have to get the Button replaced. Else there's something wrong with the motherboard. Kindly get back for any clarifcation.
Jan 09, 2009 | Computers & Internet
ASUS M2N-SLI deluxe
for start
lets remove everything non essential to start up the pc.
Try with only one memory.
recheck psu connectors.
Jun 09, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
May 10, 2008 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Asus a8v fail
does the power supply fan run when switched on.
does the hard drive spin up .
Have you reseated the video card.
Jan 26, 2008 | ASUS A8V Deluxe Motherboard
Intel D845GVSR Motherboard Logo
78 people viewed this question
Top Intel Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
