Question about HP Deskjet D2360 InkJet Printer
Hp deskjet d2360 paper jam
Taken paper out. cleared at back no paper jammed. still saying paper jam
  • lauraunwin76 Feb 04, 2009
    my printer says that is has a paper jam but there is no paper in there. Help!!!
  • zensabio Feb 11, 2009
    removed paper jam, but printer status is still paper jam. won't print.
Dear sir
I miss my Driver CD so I want this Deskjet D2360 Driver
Posted on Jan 28, 2009
My HP Deskjet D2360 won't print. Print jobs get stuck in queue.
Turn off and remove the ink cartridge from the printer and open the screws at the back side of the printer. you may have pieces of paper that might have got jammed before... remove those wastes and connect everything back...
It should work...
Apr 22, 2011 | HP Deskjet D2360 InkJet Printer
My hp deskjet says there is a paper jam when there is none and will not print
If your printer for any reason reports a paper jam, withput going through the "clearing paper jam" procedure it may not respond to print command. So follow the procedure below:-
Clearing paper jam in a printer is simple almost seven step procedure depending on the printer. Paper jam is the term used to refer to the scenario where your paper fails to come out of the printer during the print process. When you send a document to the printer, normally the printer prints out the document on a paper; then you can pick up your printed copy. When the paper gets stuck in the printer, it is said that paper has jammed in the printer "paper jam".
Even if you are not a technical person, you can conveniently clear paper jams. All you need is to follow the set of procedures outlined below.
Good luck & God bless!
Mar 01, 2011 | HP Deskjet 3845 InkJet Printer
My hp printer d2360 doesn't print.the papers are getting stucked.
clean the rubber rollers of your printer they might be too dirty that causes the improper movement of paper and cause the paper jam..or open the cover of your printer check for the brocken belts .or paper rollers
May 20, 2010 | HP Deskjet D2360 InkJet Printer
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
Middle light blinking message says paper
Look for any small rips of paper caught in a sensor back there. There are little "fingers" that the paper runs over and its all timed. if one of those sensors are jammed with something or sticky, error messages.
Sep 22, 2009 | HP DeskJet 550c InkJet Printer
Paper jam display even though no paper jam anymore, unless there are tiny pieces left inside after i pulled the paper out
check near where the paper enters the roller for pick up and use a stiff brush to clear anything small in there. vacuum the area and then power up to see if this helps
Aug 08, 2009 | HP Deskjet D2360 InkJet Printer
Omg..
there could be three reasons for this problem
1)the printer cover is not properly closed.
2)either any of the cartridge is faulty.
3)or there is literally the paper jam in the printer.so at the back of the printer there is a assess door just remove that door and you can see inside any paper jam.also look for any minute tiny pieces of paper blocking the gears to forward and it shows paper jam.
thanks.
Oct 13, 2008 | HP Deskjet 2360 InkJet Printer
HP Deskjet D2360 InkJet Printer Logo
413 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
