Question about Maytag Neptune MDE6700A Electric Dryer
Breaker keeps throwing
I have a Maytag Neptune dryer that recently has been causing the breaker to throw. Once reset, it may or may not work for a bit then is thrown again. I checked all the ducts and they were clean. Unit was purtchased in Aug 2006. What might be causing the breaker to throw (30 amp breaker)?
    Scholar:
  • 76 Answers
Jhweis80 Why do you think the problem is the dryer? The circuit breaker itself could be bad and this is what I will check first. Probably you need a professional electrician to do it for you. Gendos post back...
Posted on Jun 27, 2007
6ya staff
SOURCE:
What will cause my maytag dryer to throw the breaker when i try to start it
Not a dryer pro but if the dryer is on a circuit that's already loaded up, or is overloading your current one (amps wise) that could cause it, and especially if the breaker is weak. Could be shorted capacitor or drive motor, or heating coil short situation. (wire melts, ends up shorting against housing). If the breaker checks out, suspect the heater element next, motor last, I'd say. Good luck. Maytag Dryer Trips Breaker
Mar 15, 2015 | Maytag Dryers
Ecosmart ECO11 throws breaker halfway through the shower
You could have a weak breaker, Check the amp draw on the breaker while the heater is running and if it is not pulling more amps than the breaker is rated for replace the breaker, If it is pulling more amps than it is rated for you have a element or thermostat going out and causing to high of a amp draw throwing the breaker. Good Luck
Dec 21, 2013 | Water Heaters
My Maytag neptune dryer was tripping the circuit breaker. Then it just lost power and quit. What could cause this and how do I fix it.
This could be a bad breaker or a loose connection in the dryer plug/outlet. If the dryer just will not work at all and there is voltage at the dryer's outlet, then the dryer is defective. I would then suspect the motor as the culprit.
Mar 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Circuit breaker trips after 10 minutes
could be a weak breaker,or poor high resistance connection from panel to dryer plug, then have someone check the current draw on the dryer while operating and see if it's within specs of the machine tag, if it's higher than that you may have a defective motor or heating element to case causing a higher than normal current draw
Nov 09, 2009 | Maytag PYE2300AY Electric Dryer
I have a Maytag Neptune Elect dryer MDE9700, that won't heat. It worked fine until yesterday. A breaker kicked off, I reset the breaker and now dryer will work it just doesn't heat up. There is no error...
Your heat strip has burned out, shorted against the frame, and kicked the breaker. Take off the back, it is not hard to replace. Be sure all breakers are turned off.
Apr 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Electric Dryer
pf = power failure
do= door open
the dryer is tripping the breaker because your house wiring is probly not up to snuff, or you have a bad breaker. nothing you are saying sounds like a dryer problem, but could be a big issue with house (could be very bad, could cause fire)
May 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryer and breaker
you have a week breaker or a breaker that is to small you need a 40 amp breaker 20 on each side (two breakers locked into one) or worse you have a short in the dryer. If dryer runs for a little bit and then shuts down its the breaker.if it throws breaker as soon as you plug it in or start it then the short is in your dryer good luck
Dec 29, 2007 | Maytag HYE3658AY Electric Dryer
Dishwasher keeps throwing circuit breaker halfway thru cylce
Most likely cause is a minor leak shorting acroos the wires, check in base for water stains. Regards Advisor
Aug 31, 2007 | Maytag 24 in. MD5600 Jetclean II Built-in...
Maytag Neptune MDE6700A Electric Dryer Logo
112 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
