Question about Bernina Artista 180
How to convert bernina artista designer memoHASP-1 dongle to usb so I can use on new laptop
3 Suggested Answers
SOURCE: I need to convert my parellel port dongle to USB
I have the same problem...V3 software. have not heard of an adapter. The software wouldn't work with Windows XP or Vista anyway. I upgraded to Editor plus V5 but have kept my old Designer plus on an ancient laptop so I can transfer old patterns. You will also find that your new laptop doesn't have a serial port to accomodate the old cable to bernina 180. Unfortunately it's always the case with updating a PC. Everything else has to follow! My advice, get hold of an old laptop:)
Posted on Jun 18, 2009
SOURCE: Dongle
Hello. No, the only way you are going to get this to work is to replace the software with new ones, as all software come with different dongle numbers. The dongle numbers are specifically for the software that you have, you can't even change dongles. Can you get in touch with the seller to give you the dongle? I have a set of Cracked software for the BERNINA ARTISTA 180 that I can copy for you for $200, which you don't need a dongle for. Email me on: lfr6@bigpond.com I have a BERNINA ARTISTA 180 as well and this is the software I run. RRP for the VERSION 3 and the CPS software is $4500.00. Thanks. Lawrence
Posted on May 26, 2008
Lost dongle bernina 180 artista version 3
Unfortunately, your dongle is like a Key that is made just for your machine. You could try contacting Bernina or the place where you bought the machine originally and ask if they can send you a replacement. I've afraid it will be very expensive though.
Good luck.
Mar 15, 2014 | Bernina Artista 180
I had to buy new computor got a 25 pin put in for dogle downloaded hasp drive but still says security device not found. Help!!!!!!!!!!
Welcome to Fixya
May i know the brand and model of the device that you are trying to connect to your computer? Where are you seeing the error message?
Your response will be highly appreciated.
Thank you for using Fixya!
May 16, 2011 | Bernina Artista 180
My Bernina Artista 180E no longer works with updated Windows. Is it possible to upgrade so that I can still use my 180E and not have to buy another machine?
Just use the free download software from Bernina called Artlink. I used it along with a USB to Serial converter cable to connect to the machine. Works wonderfully. Allows me to still use my old Artista designer software if I want to on an older machine and then when I want to actually transfer the designs I use the laptop with the USB cable.
Feb 01, 2011 | Bernina Artista 180
How to repair a bernina hasp lock
HASP or security device dongles were used on earlier Artista software. If your machine still has a parallel port and the HASP devie is on the connector then you probably upgraded windows over time. There is a XP device driver fix you may need to install. I recently loaded the ancient Artista software into a modern machine so I know it can be done. Just need to have the proper hardware support.
If all your trying to do is communicate with the machine from the PC then look into an USB to SERIAL converter and use the Artlink software from Bernina (free). Has much of the function that the earlier software did except for limited edit capabilities.
Jan 02, 2011 | Bernina Artista 180
Jun 16, 2009 | Bernina Artista 180
Cannot open Bernina Software - States Hasp not installed -100 -
More likely the software you have is a corrupt one or is not compatible with windows ME.
However, to be on a safe side, follow the steps :-
 1. Remove the dongle from the USB port.  2. Uninstall the software.  3. Restart the PC.  4. Download the software.
 Make sure that the software is compatible.
 Unless change the CD or download the software from some different website ( In case you are downloading it from a particular website ).
Thanks.
Mar 25, 2009 | Bernina Artista 180
New computer won't work with Artista software
You need a new security code. When we changed computers we worked with the dealer on where to send the form requesting Access code. You can find the form under Help on the far right of your menu bar. It's the last item called Access Code Order Form. They emaild it back to us with the code we needed along with the install instructions. The dealer should also be able to assist you with your laptop issue, although you may only be able to use the software on 1 PC or laptop as you are probably licensed for 1 copy, and they us the dongle to validate the software and the machine combination.
Best of luck.
Nov 20, 2008 | Bernina Artista 180
Connection problem with computer to sewing machine and reader/writer
It is not true that the 180 is not compatible with new software.
I'm owning a artista 180 from 2002 and just installed the software designer V5+ on a laptop with windows vista.
The only problem was that there was no serial port on the laptop, now I have a new cable with USB ans serial output and the software works very well !!
When you contact Bernina you will get the same answer.
greetings Carla
Jul 16, 2008 | Bernina Artista 180
Dongle
May 02, 2008 | Bernina Artista 180
Artista v3.0 security dongle
I am using a docking station for my laptop that has a serial port.
Dec 26, 2007 | Bernina Artista 170
Sewing Machines Logo
120 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
