Question about Jenn-Air 30 in. JGD8430A Gas Cooktop
Jenn-Air JDG8430 Ignitor spark - Jenn-Air 30 in. JGD8430A Gas Cooktop
4 Suggested Answers
weblord
  • 507 Answers
SOURCE: Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
replace the igniter.
Posted on Oct 20, 2008
  • 899 Answers
when you turn the dial a switch is engaged to start the ignitor , or if there is a sensor(one for the two bottom , one for the two top , it may not be reconizing that they are lit ,or the problem is sticky switch in the the dials, but I believe its a sensor that detects both of those burners that stops the spark
SOURCE: Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Posted on Feb 15, 2011
How to remove the glass top on my Jenn-Air JGD8430ADS
do not think you will gain access to the ignitor from the top .
Dec 07, 2014 | Jenn-Air Cooktops
The right side back burner will not light. There is gas, I can smell it but the spark will not start. BUT, the spark will initiate and light the front right burner. What is going on? Its the same...
Can have below issue.
(1) Electric current is not reaching the ignitor. (wire is broken or have a leak)
OR
(2) Having problem with ignitor. (need to replace the ignitor)
Feb 03, 2011 | Jenn-Air 30 in. CVG4280 Gas Cooktop
The stove top seems to be clicking, but the burner won't light
A common problem with that type of ignitor is that the porcelain insulator (much like a spark plug has) can crack easily. When it does, there will be a clicking sound, but the spark no longer arcs from the top of the ignitor post to the burner and cannot light the gas. Without an intact insulator, the ignitor is effectively shorting out and needs to be replaced.
Dec 27, 2010 | Jenn-Air JGC8536 Gas Cooktop
No spark...tried washing to be sure it's clean...dried it and still no spark.
The ignitor module may have gone bad...this is a fairly common problem...Another thing you can do is to look at the ignitors where they come through..make sure that none of them is grounding out...this would cause no spark also....if you have the proper equipment, you can test the input voltage to the ignitor module to see if it has juice...if it does , then most likely the ignitor module...these are available from most appliance parts stores...or the manufacturer
Dec 20, 2010 | Jenn-Air Cooktops
We have a Jenn-air JGC8430ADS. The rear left
WE have a Jenn-Air JGC8430BDW gas cooktop. How do i replace a broken ignitor?
Feb 13, 2010 | Jenn-Air Cooktops
My Jenn-air stovetop won't stop sparking. It goes
yes it causing a false ground
giving the ignitor a false gorund will make it fire
it should calm down or you can turn the flame on and let it dry
Oct 09, 2009 | Cooktops
Bad ignitor needs replacement
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
Oct 23, 2017 | Jenn-Air JGC9430ADS Gas Cooktop
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
Jenn-Air 30 in. JGD8430A Gas Cooktop Logo
37 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
