Question about Car Audio & Video
My Jensen Phase Linear Series UV10 cd player wont play music out my door speakers but my beat work
5 Suggested Answers
  • 4 Answers
SOURCE: i need a remote for my jensen phase linear uv8
Get one off of ebay. Just received one for bout 30.00 Good luck
Posted on Jun 08, 2009
SOURCE: jensen uv8 sub works with radio an dvd but not with cd
quiero instalar mi dvd car radio y violar el codigo de parqueo se que hay opciones para poder estar el vehiculo rodando y poder verse el dvd gracias
Posted on Sep 13, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have a jensen uv10 phase linear in-dash dvd
No disc error can be a DIY like the following steps.
Assuming that the disc is good.
1.Cleaning the lens. - Sometimes because of dust the lens can't read any disc.
Try clean the lens by soft cotton buds. Be careful while doing this.
2.Replacing the ribbon - Check the ribbon connected to the lens from the main board for scratch, damage. Once it has an open line then of course the lens can't read the disc. Also try to erase the contact by pencil eraser.
If you've done the steps above and the symptoms still there then the next step requires you a little knowledge in soldering technique and reading the ohmmeter.
3.Checked the motor - Check the motor that spin the disc with an ohmmeter. You can test it using the ohmmeter (x1) even it is connected on the lens assembly.
Good motor - reading should be fairly high and it will spin.
Bad motor - reading will drop to low resistance and will not spin.
Hint : 50% of my repaired unit the above parts are commonly caused of the problem.
If you confirmed that you have a defective motor then replace it with a new one. Before replacing the new motor you have to check the clearance of the disc holder with the old one. The clearance should be the same as the old because if not the lens will not read the disc if it is too far or too close.
If you already cleaned the lens, and confirmed that the ribbon is good as well as the motor then I've advice you to send it to repair shop because the next step should be done with an expert because it is quite technical diagnosing the fault between the pick-up lens and the main board.
Thanks for using fixya.
Please rate my help.
Posted on Jan 25, 2011
SOURCE: wiring harness
We're can I get a harnest for my sub outputs an inputs
Posted on Dec 14, 2012
How do you switch the am/fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen with no remote?
touch source button in the upper left corner until the tuner options are on, or until you see the stations,m then hit seek or tune to get the station you wish to play.
Nov 21, 2014 | Jensen Car Audio & Video
How do you switch the am and fm on the Jensen Phase Linear UV10 Flip Out MultiMedia Receiver with 7-Inch Touch Screen
touch the source button in the upper left hand corner until you see radio, then hit tune or seek to get the stations you wish.
Nov 21, 2014 | Car Audio & Video
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
Wiring harness
wiring pin layout ginseng UV chan DVD iPod USB navigator and Bluetooth ready he's being good receiver 7 inch TFT 1200
Apr 16, 2010 | Phase Linear UDV9010 Car DVD Player
Music video
When you burn the videos to a cd or dvd disc make sure it is in one of these formats: Video CD (VCD), DVD, SVCD because thats what video formats that HU plays
Mar 28, 2010 | Phase Linear UDV9010 Car DVD Player
Jensen Phase Linear uv10 dvd wont play while driving
When You installed it the pink wire that said to brake did you put it to an actual ground instead of the barking brake?
Jan 03, 2010 | Jensen Televison & Video
Bad disk
Wow! That's a first. I used to sell both the Jensen AND Phase Linear versions and never a problem. It sounds like a bad unit. You say it plays NOTHING? No CD's OR DVD's that are the factor made?
The only thing I hav up my sleeve is to do a reset on the unit. If it has a button (I don't think it does frm what I remember) use it first, then with the unit ON, unplug the poer plug, wait a few, then plug back in and see.
Sorry I have no more tricks foir that,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Jensen VM9510 Car DVD Player
No cd audio from my phase linear uv8
It sounds like you have a factory amp in the vehicle. Check behind the radio to see if you have the blue wire from the deck hooked up to anything. You probably do. So take the blue with white stripe wire coming from the deck and hook that up instead of the solid blue wire.
Jan 20, 2009 | Phase Linear UDV9010 Car DVD Player
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
