Question about Panasonic SD-YD205 Bread Maker
I have the SD-BT56P Panasonic Breadmaker which I haven't used in quite some time. I and't remember what size loaf It makes 1 or 1.5 #?
3 Suggested Answers
daryl441918
  • 1280 Answers
SOURCE: I have a panasonic sd
That is a problem with all breadmakers. The only way to prevent this is to remove the dough ball from the machine after the final punch down and just before the final bake. I've never done that but it might be a solution, but I have heard others talk about it. If you choose to leave the paddle in as I do then use a toothpick and poke around the outline of the paddle with it. You will still have a hole but it won't be as large. I sometimes use a popsicle stick too. Whatever you don't use anything metal to get it out if you have a metal paddle because you will scratch the non-stick surface on it.
Posted on Oct 16, 2010
breadwizard
  • 132 Answers
SOURCE: My panasonic SD 255 breadmaker, after quite a lot
You never said if you remembered to select the LIGHT Crust setting each time. Did you? Are you? If you ARE using the LIGHT Crust setting and finished loaves are still too dark, I would have to say it's time for a replacement breadmaker. Nothing lasts forever my friend. Besides, it sounds like you got your money's worth anyway, right?
I've owned over 200 breadmaker myself so you can bet that what I'm saying is true. Sorry for the bad news friend.
Hope this helps!
Posted on Jun 25, 2011
How many pounds is xl bread
an xl loaf would be determined by the amount of flour you use. a standard 2lb large loaf is made usingc 560gms (19.7ozs)flour. i make my loaves using 850gms (30ozs) flour. the end result is an xxl loaf. (i don't bake it in the bread pan. i have an extra large loaf tin. one thing to note, is when using more flour all the other ingrediants apart from the yeast need to be increased too . good luck.
jackie
Feb 16, 2013 | Panasonic SD-2501WXC Automatic Breadmaker...
I have used my Panasonic breadmaker successfully for 2 yrs, today I decided to make a loaf of bread using the basic default 4 hr programme but it starts and the time elapses but the paddle does not go...
plug it out from the current outlet and let it stand for about 2 hrs..that should correct the problem by the set reseting itself..if that does not work then buy a new set repairs will be too expensive.good luck.
Sep 13, 2011 | Panasonic SD-YD250 Bread Maker
Recipes for b&d breadmaker model 2300
Knowing your breadmaker's loaf capacity will enable you to find recipes of any variety on the Internet for free.
It will also keep you from adding too much ingredients which could cause dough to over-rise and spill onto the heating element.
Remove your bread pan from your breadmaker. Using a one-cup 8-fluid-ounce liquid measure, fill your bread pan with water. As you do, count the number of cups it takes to fill your bread pan to the very rim.
Generally speaking...
If your bread pan holds 7 & 10 cups to the rim then you have a 1.0 lb or 500 g loaf pan
10 & 11 cups to fill = 1.5 lb (700 g) loaf pan
11 & 13 cups to fill = 2.0 lb (900 g) loaf pan
13 & 15 cups to fill = 2.5 lb (1250 g) loaf pan
15 & 17 cups to fill = 3.0 lb (1350 g) loaf pan
A bread recipe for use in a 1.0 lb (500 g) breadmaker should never exceed 2-1/4 total cups of flour.
1.5 lb (700 g) = 3-1/4 c
2.0 lb (900 g) = 4-1/4 c
2.5 lb (1250 g) = 5-1/4 c
3.0 lb (1300 g) = 6-1/4 c
Warning: When testing a new bread recipe it is always best that you not leave your breadmaker unattended. Stay close by to monitor its progress from time to time.
Did this answer help? I hope so. Please rate it as soon as you can. Thank you.
Jun 26, 2011 | Black & Decker B2300 Bread Machine
My panasonic SD 255 breadmaker, after quite a lot of use, is now baking bread with a harder crust than it did in its youth. We can get a softer crust by using the Sandwich loaf setting but then we can...
Hope this helps!
Jun 15, 2011 | Panasonic SD-YD250 Bread Maker
I have a Toastmaster Automatic Breadmaker. Model 1196. I need to know if it is 1 pound or 2 pound breadmaker. THanks
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Nov 25, 2010 | Kitchen Appliances - Others
Just purchased the Panasonic Breadmaker SD-YD250 and wonder if the 'Rest Period' portion can be programed out or deleted. Many thanks Richard
That is usually part of the whole wheat program. I don't know if you can program it out or not but you could compare the program with the "basic" program and try using that instead if you think it might work. To have a decent loaf you may have to replace some of your whole wheat flour with bread flour and perhaps some vital wheat gluten and experiment to see if you get a good loaf. Many bread makers have the rest period to start their whole wheat program.
Oct 28, 2010 | Panasonic SD-YD250 Bread Maker
I have Panasonic bread machine model SD-YD150. I have its replacement Sensor part number ADA11A107. I also have Panasonic bread machine model SD-BT56P. Its Senor part number is ADA11A108. Only the last...
The sensors parts are model-specific. I called PartStore.com at 1-866-925-7278, and they gave me the phone number to Panasonic 1-800-211-7262. A Panasonic tech gave me the info. I needed.
Jan 15, 2009 | Panasonic SD-YD250 Bread Maker
Bread too high
The one thing that rises bread is yeast. You have some super duper yeast if the breadmaker suggests a certain amount and you keep getting the same results. You can either reduce the rise time -- or the amount of yeast -- or both.
Jan 07, 2008 | Black & Decker B2000 Bread Maker
Panasonic SD-YD205 Bread Maker Logo
179 people viewed this question
Top Panasonic Kitchen Appliances - Others Experts
Irene Tulloch
Oloyede Monsuru
Are you a Panasonic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
