Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Too cold in frig
The vegetables in the veggie drawer routinely get a layer of ice on them. Also, had meat in lower portion of frig and three of four steaks froze. I have turned the temperature setting way down, but it doesn't seem to make a difference.
Read somewhere about blowdrying the freezer vent. Does that make sense?
  • maofournj Mar 20, 2009
    No matter what I set the fridge at veggies and my water and juice are frozen slightly.
    Problem Solver:
  • 5 Answers
Check for a faulty thermostat it is responsable of shutting down the compressor when it reaches your desire temp.
Posted on Mar 06, 2009
Where do I put cold cuts and meats I don't want to freeze?
Best place for cold cut meats is the bottom drawer in the refrigerator. It's also good for cheeses. That drawer is the coolest but not freeze place. The upper two drawer are good for veggies and fruits. We put the lever controls in the middle selection for them.
Aug 02, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What is setting for fruit and vegetable draws
Lower humidity is more cold air going in. Higher humidity is les air. Veggies in higher humidity and fruits in lower. Meat can also be be stores in lower humidity.
Sep 07, 2012 | Maytag MFD2560HES Bottom Freezer French...
The meat and veg drawers freeze the meat and veggies no matter what setting the temp. is on.
Freezing meat,vegetables. Problem with damper.
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.
----------- This should help. Thanks.Helpmech.
Jul 08, 2011 | Kenmore 56829 Side by Side Refrigerator
Our vegetables are freezing in the bottom of the veggie drawer
Try moving the veggies to a different drawer or lowering the cooling setting for the Refrigerator
Jun 21, 2011 | Refrigerators
My Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator bottom meat section and veggie drawer is freezing my meats and vegetables. Why?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The temperature for the top portion is reading 38 degrees, however we often find vegetables partially frozen in the produce drawer. The icemaker continues to function but the filtered water spigot will not...
turn your unit up to 40 degrees, by the time the upper portion hits 38 degrees the bottom is close to 6 degrees colder than the upper, by physics cold air is heavier and falls, plus w/o a fan down there it will freeze quicker,just like a cold night outside with no wind to speak of,try this once,also you may want to shuffle the food around the refrig box and try different levels, iI know that the veggies belong in the lower crisper drawer usually though
Oct 27, 2009 | Refrigerators
Why are my veggies freezing even thought the temp is set to 40?
Most fridges have crisper drawers that have a selection lever on either the front or side of the drawer that allows you to select eiher veggies or meat. Veggie setting is supposed to keep the crisper drawer warmer, while Meat setting makes it the coldest possible.
If you don't have the selector slide levers, I would suggest you use the highest possible crisper drawer available, as the lower in the frdge compartment you go, the colder the air will be. That should resolve the problem you're having, other than lowering the fridge temp setting slightly.
You might notice a cold air exchange vent next to your crisper, which supplies cold air from the freezer section into the fridge section, so that could be contributing to the colder temps in the crisper where you keep your veggies.
Hope you find this Very Helpful and best regards!
Aug 20, 2009 | Jenn-Air JBL2088H 20 Cu. Ft. Cabinet-Depth...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
143 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
