Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Ge profile harmony won't stop filling - GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
5 Suggested Answers
Jahn27
  • 1554 Answers
SOURCE: WPGT9360EPL GE Profile Harmony won't drain stops at
Check to make sure that the drain hose is clear then unplug the machine. Remove the 4 Phillips-head screws (2 on each side) that hold the back cover in place and then remove the back cover
Remove the thin plastic cover over the drain pump by pulling down on the ends to clear the tabs.
Lift up the tab on the impeller housing with a flat-head screwdriver. When viewed from the impeller housing end, rotate the motor in a counter clockwise direction to remove.
Remove any foreign objects from the impeller and impeller housing. Inspect the impeller for any damage and replace the pump assembly if necessary.
The drain hoses are difficult to remove due to a sealing compound used at the factory. To remove the drain pump, remove the drain hoses from the pump by squeezing each clamp and slide it back. Carefully break the hose loose by inserting a small flat-blade screwdriver or any similar tool under the hose to break the seal and remove the hose.
Remove the 2 Phillips head screws that hold the drain pump mounting plate to the washer floor.
Disconnect the drain pump wires then remove the 2 Phillips head screws that hold the drain pump to the mounting plate and separate the drain pump.
Care must to taken when reinstalling and sealing the drain hoses to the outer tub to ensure there is no water leakage. When installing, apply a thin coat of sealing compound to the inner surface of the drain hoses.
You don't have to accept or reject this post in order to add comment or information. But accepting the solution should you find it helpful and/or informative will not stop you from posting comments or additional information. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Posted on Jul 16, 2011
VtToolMan
  • 704 Answers
SOURCE: GE Profile Harmony Washer has loud squeak when filling
Based on your description, it sounds like the water inlet valve is making noise, since you hear a squeaking noise during the filling of the washer. If it sounds like a constant squeak or squealing noise, i'd say it's caused by either the water inlet valve not being pulled all the way open, or because the water supply shut off valve at the house end isn't open all the way. Try opening the water supply shut off valves all the way open, (check to see that they are).
What is interesting is that the squeaking comes back during the draining of the water. Is this while the tub is spinning or only at the very end of the cycle? Again, it could be the water inlet valve, since the washer will "spray" some fresh water into the washer during the final spin cycle to help remove any soap residue, etc.
The part ins't cheap at around $123.00 for this valve, so unless it's really annoying you to no end, I'd wait for the valve to stop working before getting the repair done, unless you want to do the repair yourself, which isn't difficult, with some basic tools and time.
If you wait and let this go until it fails, you'll notice the water in the tub might not fill all the way for the level set, or the valve will start getting even more as it gets worse.
Here's a drawing that shows your washer and the part I'm talking about.
pd_0026_363_wh13x10017?$pddetailsth$ Part #WH13X10017 $123.49 @ searspartsdirect.com
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WPGT9360E0PL&productCategoryId=0153200&brandId=0432&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROLS,%20BACKSPLASH%20&%20TOP%20PANEL&documentId=G0901083&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Jahn27
  • 1554 Answers
SOURCE: My GE top load Profile Harmony washer will fill a
The message merely notifies you that there's a problem. Enter service mode in order to get critical information on the status of various components of the washer. This mode will help you identify failed or improper operation of components and systems. The service mode does not use error codes to identify problems. Instead, the LCD screen displays a list of components or systems to be checked if a problem is detected. Once the service mode is entered, all membrane key panel buttons are disabled.
Press the POWER key to turn the washer on. If the washer is on and the HOME screen is displayed, press HELP and the main help screen is displayed. If the home screen is not displayed, press HOME on the keypanel then press HELP to display the main help screen.
Press and hold MY CYCLES and BACK simultaneously for 3 seconds: The control will display any recorded errors. If no errors have been recorded, press EXIT to return to the HOME screen. If errors have been recorded, post it back. A MORE icon will be displayed on the LCD screen if additional problems have been recorded. Press MORE to list additional errors.
Use the BACK pad on the key panel membrane to scroll back through the list. If MORE is not displayed then there are no additional errors. Make a note of the listed errors. Press EXIT, the screen prompts you to unplug the washer before servicing.
Pressing exit clears all error messages and activates the setup mode program. Disconnect power and make necessary repairs. After the problem has been identified in service mode and repairs have been made, the unit prompts you to run a setup/self diagnostic check. The self diagnostic check consists of a series of system tests to ensure the washer is operating correctly. Follow the on-screen instructions.
When all errors have been corrected and the setup/self diagnostic mode has been completed, the washer displays the following screen. Press OK to return the washer to normal operation.
Posted on Sep 17, 2011
richroth
  • 9472 Answers
SOURCE: My GE front loader will filll but won't stop filling and wash, it just keeps filling then clicks to pause
Does it stop filling if you stop the cycle or do you need to turn the faucet off?
Posted on Nov 28, 2012
Where is the lid switch located on my GE Harmony washer?
It is usually within the lock mechanism, try putting a small bar or something That look like the bar of door latch thru female mechanism, It should start when activated ( stop It when it´s filling up before There is enough water, you should not get swamp... )
Feb 03, 2015 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
The spin cycle on my GE Profile Harmony washer has gone violent, what can cause this?
probably unbalance load inside, try to stop, move what's inside and restart, or maybe there is not enough inside and cannot balance ( one heavy item, add some item so it can balance them when spinning )
Nov 29, 2014 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Nov 28, 2012 | GE Washing Machines
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Elec. Dryer Blower Stops working or won't start up
Do this.
press "Home"
press "Help"
press both "My Cycles" and "Back" at the same time and hold them until service mode pops up.
It will tell you what's wrong.
Jul 22, 2009 | GE Profile Harmony DPGT750EC Electric...
Harmony Start/stop button cover
IF IT WHAT IM THINKING ABOUT A LITTLE SILICONE WILL DO IT
Dec 10, 2007 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer STOPS without pattern
You didn't state whether or not you were getting an error code. On this model if the blower motor exceeds 3000 rpms for one minute the dryer will stop. Usually this is caused by a clogged or pinched vent hose or vent itself. Check this out first. You can find the tech sheet under the consol. I believe it unscrews from the back and lifts up. This will give you detailed info on how to enter the diagnostic mode. If you cannot find the tech sheet, post back and the cat here will walk you through it. Catriver..post back.
Oct 24, 2006 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
