Question about GE Profile Harmony DPGT750GC Gas Dryer
Electric whirlpool dryer not heating
They dryer is blowing normal just not heating up at all
    Guru:
  • 462 Answers
Check for 220 Volt at the heater entrance to the heater box (accessible from picking up the top on most models). If you have 220v there the heater element is out. If you don't have 220v on the terminals of the heater the problem is in the controls. The fuse link, the timer contacts, the centrifugal switch on the motor, and the heater safety thermostat and operating (s), are all suspect and have to be eliminated 1 by 1. Hope this helps. With any luck all you need is a new element. Clean the duct out while replacing the heater if so because the main thing that causes heater element burn out is low air flow a kinked Dryer vent hose, lint, and plugged up fan on the motor are the 3 main causes of low air flow. If yours has little holes in the inside cabinet these can get clogged with lint also and cause a problem. Hope this helps and please rate me accordingly Thank you and good luck.
Posted on Mar 13, 2009
No heat on whirlpool dryer
should also tryif you have a old house with fuses sometimes you only blow a partial fuse your dryer might run but not turn the element on for the heat
Mar 29, 2014 | Whirlpool WED6200S Electric Dryer
I have a Whirlpool electric dryer M/ WEP5300o that will not heat. I have replaced the Cycling Thermostat, High limit thermostat, Thermal fuse and heating element. It still doesn't heat. There are
If you have fuses on your electric panel it normally uses 2 fuses, 1 for electric power 1 for heat. The same may be true on the circuit board panel check this to eliminate this possibility
Feb 02, 2013 | Whirlpool Dryers
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Thermodisk keeps going out
Three words for you: Airflow airflow airflow.
I estimate 95% of all (electric) dryer no heats are caused by a lack of airflow causing the thermal cut out to blow.
Clean dryer venting system (dryer vent hose all the way to the exterior vent on the building) and clean the dryer itself from lint filter to the blower wheel.
It is also possible your blower wheel may be damaged and not giving the airflow needed to keep the dryer within normal temp limits.
Oct 21, 2009 | Whirlpool LER8648P Electric Dryer
No heat on our clean touch electric dryer, it turns and blows air but it does not have heat
Sounds like the problem is you have a faulty heating coil or thermostats.
Remove the back of your dryer and located the air tube that goes from the blower to the drum.
Normally inside the air tube you will find the heating coil and the thermostats.
I hope this helps
Oct 02, 2009 | Whirlpool Dryers
My Whirlpool geq8811ll1 dryer turns on and spins but doesnt blow
you probably have one of the wires not connected correctly. or you could have bad themostat.
Sep 01, 2009 | Whirlpool GEQ8811L Electric Dryer
My Electric Dryer's Heating Element Glows orange while in use
Hi. this is quite normal when you dry heavy items. the dryer has sensors inside the compartment that will sense cotton and wool garment. if needed, the thermal regulator will adjust the element to the appropriate range. If there is a problem, the electronic thermal fuse will blow. this is the safety feature that will trigger itself if a fire or over heating is sensed. Also, if your selector knob is set to a cotton or high heat mode, the element will normally glow intensively during this cycle.
Please rate and god bless.
Mar 19, 2009 | Whirlpool Dryers
Whirlpool Electric: Light is on, but no turn or no heat
Hi, Good troubleshooting! If the light stays on and nothing works it indicates the door switch is the problem. Best of Luck to you! Please rate my response.
Feb 09, 2009 | Whirlpool LER5636P Electric Dryer
GE Profile Harmony DPGT750GC Gas Dryer Logo
161 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
