Question about Dryers
How do you remove the top of the Moffat dryer to get at the fan?
Model # RVXR353EB1WW We are trying to remove the top of the dryer to clean the lint from the door but cannot slide the top off. How do we get access to the fan?
  • 65 Answers
SOURCE: Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Posted on Feb 16, 2008
SOURCE: Whirlpool Gold Dryer GEQ9800PW1
take a screwdriver and push it in below the door at the top of the bottom panel, near each end of the panel, there is a springclip to pry on that that releases the panel and it will fold out and then lift off. then you can get access by removing a few screws.
BE SURE TO UNPLUG BEFORE WORKING ON IT.
Posted on May 18, 2008
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
SOURCE: How do I remove the lint trap holder to clean out the lint inside
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). The screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is a housing that leads to the exhaust blower. It will be packed with lint that may be hardened like papier mache. Just clean out the mess & reverse the process to replace the parts.
the
Posted on Feb 11, 2009
How do I take apart Moffat Dryer Model RVSR363EH7WW
It is very easy ,just lift top and remove front and pull drum out of dryer and do reverse to put them back
Feb 26, 2015 | Dryers
I need to change the door switch. I have the part. Should I take off the top or the front to change that part?
For the model dryer you have listed, the easiest way to access the door switch is to lift the top panel. The switch can then be removed and replaced by following these steps:
1. UNPLUG the dryer and remove the lint screen.
2. Remove the two screws that were under the lint screen and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Remove defective switch and replace.
NOTE: Now would be a good time to do a routine inspection and cleaning of the interior dryer cabinet to ensure there's no lint build up.
Once repairs are completed, lower the top panel back in place and reinstall the two screws along the lint screen opening.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
If you have any questions about this repair, or if the model number is different, please post back and let me know. I hope this helps you.
Apr 26, 2011 | Roper RGX4634KQ Gas Dryer
How you open side of dryer model GE DSXH 43 to clean lint from the motor
unplug it,take the top off,should be screws in the top back,then you have to remove the control panel,sometimes you can just leave it on top of drum or on the side of dryer,then remove screws that hold the front panel on,you can google your model number on utube and watch a video on it.you don't have to remove the drum if you have a shop vac, you can vac up all the lint you see,then set the vac up to blow and blow all the lint from the back to the front so you can vac that up and clean out where the lint filter slides down into,then go in the back remove the vent line and you can use a leaf blower to blow out the line,usually takes 40 to 60 minutes depending on how dirty the dryer is.
Jan 09, 2010 | GE DSXH43EF Electric Dryer
Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Lint trap
http://www.pcappliancerepair.com/model-display.php This will show you how your dryer is put together. The lint has gone directly to the fan, where it could affect fan performance. You would have to remove the front off the dryer, and the cover off the fan area. It's not a bad idea to clean this area once in a while.
May 11, 2009 | Maytag Neptune MDE4000 Electric Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
ROPER DRYER WILL NOT HEAT
Put the back panel back, and hope you havent done permanent damage
the back does not come off roper dryers for service
the front does
the back panel serves solely as a mounting point for important fixtures
there is no reset button
there are thermal fuses, if the thermal fuse, mounted on the exhaust duct or fan housing has failed, it must be replaced, but they are not expensive
look like this de074eb.jpgbcb6b5f.jpg to access the dryer mechanism
unplug dryer
remove lint filter
remove 2 screws under lint filter
with putty knife or other blunt blade, depress spring catches at front corners of top cover
raise front cover
remove 1 screw each side of front panel 1/3 from top
remove door switch wires
remove front panel set aside
test all thermostats heater and thermal fuse with ohmmeter, remove 1 wire test for conduct replace wire, no conduct replace
the local parts store will have the part, labelled whirlpool, ~$14 for thermal fuse, ~$40 if heater
examine rear panel reinstall any thing that is dismounted
while the dryer is open
Clean the lint out of fan, fan housing, ducts
airflow blockage is the 99% cause of thermal fuse blowing, some lint always gets past the lint screen
Oct 29, 2008 | Kenmore 63942 Dryer
Lint trapped inside dryer housing
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
For jsrock516, it's a top lint filter.
Okay...you need to unplug the machine, first. Remove the two screws that are located at the lint filter on top of the dryer. Move the dryer out from from the wall and disconnect the dryer hose. Remove the back panel. The screws are 1/4 inch socket drive screws. With the back off, you will need to remove the dryer vent baffle on the left hand side as you are looking at it from the back. This will be the long chute that the lint filter goes into. Clean the baffle out thoroughly. With it removed from the machine you can probably get away with rinsing it with water. Just make sure you dry it off good inside and out. Inspect the blower fan assembly. Make sure you clean it off real well. I would not recommend removing the fan, as they have a tendency to break when removing. Check in and around the bottom of the dryer casing and vent exhaust tube. Make sure get all the soap cleaned up. If you don't, you can get lint accumulations and a soapy residue that turns to a sticky goo. This dryer configuration is actually easier than the front door style lint filters. Just make sure you reinstall everything in the reverse order that you have taken it off. Keep all screws in a handy container so you don't lose them (there may be a lot of them). When reinstalling the screws on the top of the dryer for the lint filter opening, you may have to move the dryer chute around a bit to get the screws to realign. Do not drop the screws down the chute, or you will have to take the unit apart again to get them out. Good luck and let me know if this helps you, and if I can assist any further. You do not have to post separate comments. Just add a comment to this exchange.
Aug 09, 2007 | Kenmore 60172 Electric Commercial Dryer
Dryers Logo
142 people viewed this question
Top Dryers Experts
