Question about Kitchen Ranges
BUSH AG66TA GAS COOKER PART FOR FLEXIBLE GAS PIPE
CANT CONNECT FLEXIBLE GAS PIPE TO COOKER BECAUSE NO SCREW THREAD FOR THE GAS PIPE WHAT PART DO I NEED
5 Suggested Answers
SOURCE: i have a cooker with a bayonet fitting that wan't
You need to check with your hardware store and get a fitting compatible with your fitting on the stove.This will have to be fitted to the wall pipe but I stress that this should only be carried out by a registered gas fitter.
Hope this helped.
Posted on May 12, 2010
  • 494 Answers
SOURCE: there is a strong smell of gas from my cooker,
Do not light anything if you are smelling gas. Make up a soapy solution in a spray bottle and apply to all connections and look for bubbles. Most common place to leak is hook-up at cylinder and hook-up at cooker. If you can't find the leak and continue to smell gas, do not use it. Also make sure your cylinder is not empty.
Posted on May 15, 2010
SOURCE: I need an lpg conversion
i need a LPG conversion manual for a Bush AG56SW
Posted on Mar 03, 2011
  • 43003 Answers
SOURCE: I BUY FROM ARGOS A BUSH COOKER THEY DELIVERY TO MY 3 FAULT BUSH COOKER.I'M STILL WITH A FAULT COOKER
call them and tell them what the problem is . we have no idea where you got or what you got
Posted on Jan 27, 2016
What type of pipe do i need to by for connecting necht gas hob to my gas
Usually it is a flexible pipe with a gas clip connector on the wall end and a standard thread on the cooker end. In the UK we employ Gas Safe technicians to install gas appliances due to leaks and possible explosions caused by an unsafe installation.
Feb 04, 2017 | Cooktops
I have just bought a second hands bush AG66TW gas cooker. Unfortunately I haven't got a manual for this. Could you please let me know where I can get this. Thank you
[PDF]bush cooker manual.pdf - WordPress.com
https://tisinglowthpho.files.wordpress.com/2015/.../bush-cooker-manual....
Bush Cooker Manual manual for bush ag66tw gas cooker. Asked by dougie on 03/15/2015 0 Answer. ManualsOnline posted an answer 5 months, 4 weeks ago.
Oct 26, 2015 | Kitchen Ranges
How to connect gasline to clothes dryer
if your 1/2" gas pipe is at the location, it should be stubbed out with a shutoff valve. the valve could be a 1/2" female pipe thread that your gas flex line will attach to-the flex line should have an adapter to fit the 1/2" female pipe thread, if the valve ia flare fitting the adapter is not used. use thread compound on the pipe threads,not teflon tape when working with gas, but nothing is required on a flare fitting.
Feb 18, 2012 | Electrolux Dryers
I have a belling gas range cooker and only one of the ovens lights properly. The other one when I turn the cooker knob and hold it the gas comes through,it lights but as soon as I take my finger off the...
When the oven lighting mechanism lights the gas, the flames heat a temperature sensor that, once hot, increases the pressure in the sensor's copper pipe and opens a safety valve to allow gas to continue to flow without you holding down the button (It's made like this so, if your flame gets blown out, the sensor cools and cuts off the gas supply, making it safe from gas leaks). These sensors occasionally fail, and very sensibly "Fail safe" - No pressure in the sensor pipe, the valve won't stay open and there is no gas to the burner once you release the button.
If you take a look inside the oven at the back where the burner is, you will see the sensor, usually the bit that is in the flame is cylindrical, about an inch long made of metal about 3 or 4 mm thick, tapering at the end. It will be held in place by a nut that fits on a thread at the base of the sensor. Running from the sensor is a copper pipe that runs to the cutoff valve. Unbolt the sensor and withdraw it from the hole it is mounted in, trace the copper pipe back to the valve (where it is usually screwed into the valve with a 10mm connector that looks like a car brake pipe connector. Unbolt from the valve. These sensors are widely used on most gas appliances (Boilers, gas fires, cooker hob burners and patio heaters all use the same kind of sensor). You should be able to get a replacement from any gas appliance service agent. If you go into a shop, take it with you. The only thing you need to do is make sure the replacement you get is long enough. If you are offered one that is slightly longer, that
Jul 22, 2011 | Belling FarmHouse 931 Gas Kitchen Range
Kenmore lp gas sealed burner stove,when opening or closing the oven door the top burners decrease in flame size and go out frequently.
This seems like a pressure regulator / flow problem. If you are running more than one appliance from bottled gas this can occurr if the supply pipe is not of sufficient size. When 'wafting the door' you are increasing air flow to the oven burners which in turn will consume more gas to balance the burn, this starves other burners that are running at the time.
Cure; increase regulator pressure (remove the foil cover to expose the screw) with the top burners alight adjust the screw 1/4 turn at a time until the flames are bright blue at heart and organge tipped. Increase as much as you can without the falme distorting away from blue/orange. If this doesn't cure it you may need to increase the size of your supply pipe to 15mm so that the volume of gas is greater and then split it off to normal lpg pipe to each apliance thereby creating a more even flow of supply. Often a system using say heating and gas fire is perfectly fine but add another appliance like a cooker or change your cooker to one which has more powerful burners and you can expose weaknesses in the flow system.
Jan 15, 2011 | Kenmore Kitchen Ranges
I have a cooker with a bayonet fitting that wan't connect the the wall because the wall has a screw fitting what part do i need to connect the cooker to this ?
Hope this helped.
May 07, 2010 | Ovens
Need to know if my cooker is a bayonet fitting
the bayonet fitting is on the end of the gas pipe that plugs into the gas main. look at the back of your cooker follow the black pipe you will see a brass end that fit to the solid gas pipe if you have a ring on the end of you flexible pipe that you can push in slightly and turn to disconnect you have a bayonet. its not the cooker that is a bayonet but the flexy pipe that is connected to your cooker. you can add one if one not fitted
Feb 02, 2010 | Belling Solitaire G755 Gas Kitchen Range
Low flame
the best way is to get a gas fitter to check the millibars coming through the pipe. it should be 20 miliibars at the meter or more and not less than 19millibars at the cooker. if its less it needs bigger pipe. simple test to do. if its wrong at the meter the gas supplier must turn it up.
Dec 04, 2008 | Rangemaster 110 (Gas) Kitchen Range
Kitchen Ranges Logo
97 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
