Question about GE Profile JGS968SHSS Gas Kitchen Range
GE Profile JGS968S0H4SS OVEN DONT LIGHT BUT BROILER DOES
SOURCE: GE Profile Spectra XL44 oven wouldn't light, stove top and broiler works
We have our second GE stove and it has started to do the same as the rest of you.  Our first stove began to suffer igniter issues after 4 or 5 years.  I called GE and was given a simple test procedure for the igniter using a multimeter that I don't remember and likely wouldn't post regardless lest someone do things incorrectly... In any event, as I understand, the gas flow is tied to the igniter temp.  As the igniter ages, the temp that it can achieve gets lower. Eventually, it hits a point where the temperature isn't sufficient to reliably ignite the gas and our problems start.  The solution is fairly simple.  Replace the igniter. So, call a repair person and tell them the problem.  They can come out and instal the new igniter.  Unless you are a licensed or certified repair person, DO NOT DO THIS YOURSELF.  Let the pros handle repair to gas appliances.
Posted on Jun 15, 2008
Maytag317
  • 1136 Answers
SOURCE: No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
Posted on May 31, 2009
SOURCE: Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
Posted on Jun 08, 2009
FixinFax
  • 3085 Answers
SOURCE: GE profile oven will not heat up past 100 degrees.
You need a new control panel circuit board.
Easy to replace.
Search www.repairclinic.com
Posted on Sep 09, 2009
  • 403 Answers
SOURCE: i have a GE profile spectra JGBP79... the oven has
Your oven ignitor is bad. To get to it remove racks from oven. Remove bottom shelf in oven. Removevmetal plate covering flame spreader if thete is one. Ignitor is located towatds the back right by the flame spreader. Turn oven on, pay attention to the ignitor, It should gove off a real bright glow. If it doesnt it needs to be changed
Posted on Feb 17, 2011
Oven doesn't heat, broiler works
Here is a tip that I wrote that will help you with your problem..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
The ignitor is your problem. You will need to replace it.
Heatman101
Mar 03, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
GE PROFILE JBP79 OVEN RANGE - OVEN DOESN'T BAKE. CLOCK, BROILER, CLEANING WORK, LIGHTS WORK WHEN CLEANING OVEN. COIL ON BOTTOM DOESN'T GET HOT BUT BROILER COIL DOES.. WHEN CLEANING OVEN LIGHT WORKS WHEN...
Could be the sensor inside the oven.Mine burnt out when using the self clean feature. Two screws un-plug replace with new. Part less than 15 dollars
Jan 08, 2010 | GE Kitchen Ranges
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge profile
let me understand, you p[lug in you oven and the broiler will automaticalle start??? not allowing you to cancel???? if that s the case unplug and remove the back panel from tyhe range, sound sas if the wire leading to the broil ignitor has shorted itself against the cabinet of the range itself, look for whiter braided wires at broiler hieght, chances arte they are hitting against hte cabinet right near the vent area.
May 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra Broiler not lighting
I'm not an expert, and I'm reading you're post while looking for a solution for our oven, so this is in no way should be taken as a suggested solution, it isn't!!!....here it is anyway: I think it might be a bad ignitor, I have replaced a couple on our stove and both times we had exactly the same symptoms you're experiencing, I think also we're in line for a third ignitor for this "less then 10 year old Magic Chef". Good luck
Jun 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile JGS968SHSS Gas Kitchen Range Logo
143 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
