Question about Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black
The HDMI light won't come on vsx 1121-k. Worked fine till last night
Disconnected, unplugged and put everything back but the HDMI light still won't come on
3 Suggested Answers
SOURCE: Pioneer VSX-72TXV used to work but trying HDMI just broke it...
I fixed it myself. Didn't realize that I loosened speaker cables on the wall panel when I moved the receiver and two were touching...
Posted on Dec 10, 2009
SOURCE: Pioneer power LED is Blinking
If that didn't work, with the power off try holding Tune + and Auto surround/stream direct buttons for a few seconds to reset the protection circuits. Make sure to keep 8" of empty space above the unit for air, as overheating can cause this problem. If it fails again, there could be bigger problems, so get it checked
Posted on Jan 24, 2010
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
My new receiver (pioneer vsx-44) worked last night when we hooked it up but does not work now. I have tried many different settings and made sure the speakers are on and not muted. I also turned it o
Possibilities: your source setting is wrong, your tape monitor switch (if it has one) is on, your speaker selector position is wrong. Do any lights come on?
Oct 04, 2014 | Pioneer Elite 7.2 Channel Network Black AV...
Audio with Digital audio cable from TV (HDMI doesn't pass sound)
For hdmi audio transfer, ur TV should have to hdmi arc enable option,
Or check with TV optical option,
If no more optical and hdmi arc option in ur TV, then no more options
U have to connect analogue only..
Dec 17, 2017 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
My car won't turn on it was working fine last
Just because you charged the battery it doesn't mean it is any good. Modern sealed batteries fail; just as you described, fine one moment and then nothing, they go open internally.
Jul 19, 2013 | Cars & Trucks
Sony KLV-27HR3 won't come on
Check to see if you are getting a back light by looking through the slots on the back cover. If you are getting a backlight then it is not your power board. If no back light check your connection in another outlet different room if possible or use a long extension. If still no back light then you are likely to need a new power board.
Good Luck Ed Pinero
Feb 03, 2013 | Sony KLV-27HR3 27 in. LCD Television
My Pioneer Receiver VSX-519V has a blinking HDMI light and won't show video.
You guys mentioned the reset via the front panel, and I tried that with this very same issue on my VSX-822-k and it worked!
thought I would post the instructions for anyone else that lands here:
Reset the main unit if the receiver is generally not operating correctly. Switch the receiver into standby mode. Hold down the "BAND" button while pressing the "STANDYBY/ON" button for about two seconds. When "Reset?" appears in the display window, press the "AUTO SURROUND/ STREAM DIRECT" button. "OK?" appears in the display window. Press "STEREO/A.L.C." to confirm. "OK" appears in the window. The system has been reset.
Oct 28, 2012 | Pioneer Vsx 519v-k 5.1 Home Theater 550...
Cant get the power to turn on,worked fine last night, it got unplugged, this morning plugged in, won't turn on and the power button just flashse
Flashing is either an error code or the set trying to boot up--some of the Mitsubishi sets if power removed will blink for a minute and then stop--then the set can be turned on.
a model number?
Apr 28, 2012 | Mitsubishi Televison & Video
Received for Christmas 2010. Worked great! Few nights ago, made something to eat, and it shut off. Light, clock, everything. After a few minutes, it came back on. Used it last night, same thing. But this...
The joys of purchasing items with a bought out warranty. Check the plug and contacts on the fuse.
You could either call a microwave repairer and pay for callout and repair or purchase a new one.
May 30, 2017 | Oster OGG61403 Microwave Oven
Dec 10, 2009 | Pioneer VSX-72TXV Receiver
Belkin router Flashing 5 out of 7 lights constantly. Help?
can you replace any cables to and from this router? Also, is it possible to turn it off for 5 minutes and retry?
Jul 06, 2009 | Belkin (F5D5231-4) Router
Pioneer Vsx-1121-k 7.1 Home Theater Receiver, Glossy Black Logo
57 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
