Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
I think the belt has snapped
I have a hotpoint aquarias vtd20.which works but the drum wont turn, last year the same problem happened ,but it was insured then .now the same things happened again and its not insured any longer.is it hard to fit a belt on one of these any info would be great thanks.
  • Hotpoint Master
  • 3,463 Answers
It is rather tricky to fit new belt.
Briefly, remove top cover, remove right hand side panel, there are screws at the back and bottom front, remove any other scews that you can see that hold the panel in place..
The front panel has to be pulled forward to enable the new belt to be fitted. You might have to loosen left hand panel as well to do this.
Fit the belt round the drum and force it over and round the motor pulley
This is a very difficult job, as the belt is a stretch belt
and appears to be too small, so you will really struggle to fit it, you will probably find it helps if you can lever it on with a screwdriver or similar.
Again, it is a difficult job to undertake, so unless you are confident you can do it, get some one in to fix it for you.
Plz rate my solution.
Thanks.
Posted on Jan 19, 2009
    Problem Solver:
  • 20 Answers
I Think your right
I have a Hotpoint Aqualtis wash/dryer which stopped working with a 'F12' fault. Now when I turn the socket on I get an immediate really loud whir/buzz.
possibly the main drive belt has either snapped or jumped off the pulley and this allows you to turn easily by hand the whir/buzz sounds like system in coming into play but with no belt to drive nothing more happens, the front lower portion of the machine could be the water pump working overtime unable to drain ???
May 09, 2016 | Hotpoint Washing Machines
Put new belt on hotpoint aquarius last one snapped but only turns with 3 items init no more but worked perfect before belt snapped?
A shaft could be seizing which is why other belt snapped, check the bearings and shaft to make sure they turn freely. Possibly wrong belt ? also check for worn pulley's.
Jan 23, 2016 | Hotpoint Washing Machines
Dryer clunking noise
hi try pushing drum at the top at the back if it lifts and nocks at all its the rear bearing cover on bake held by 2 screws you will see a pin through the shaft remove this lever bearing out to replace take lid off put bearing on shaft lift drum by rear edge so you can seat bearing
Jan 27, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Cant get top off dryer vtd00
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Jan 17, 2013 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
WIRE CONTROL PANEL
Could you please describe the problem you are having?
Oct 16, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
Aug 30, 2012 | Hotpoint Belt Drum Drive for VTD00, VTD20,...
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
Hi, I have a Beko DRCT70W tumble dryer and the belt keeps breaking. I've replaced it twice in the last month, so I think there must be another fault with the dryer which is causing this. The drum...
hi folks the beko tumble dryers have a felt seal that runs along the front of the drum that wears through causing load on the drum, belt and motor causing the belt to melt and snap, replace the felt you will have no more issues, i got mine off of ebay pretty cheap
Feb 08, 2011 | Dryers
My Hotpoint Aquarius VTD20 will not start. The lights are on, the belt is tight on the drum. It sounds as if it is trying to work, however the drum does not turn around.
is there a loose connection from the motor plug to the control board up on top of the unit
when you start a cycle does it make any clicking noises? if so then it it probably a loose connector
Jan 02, 2011 | Hotpoint Microwave Ovens
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
167 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
