Question about Singer CE-100 Futura Computerized Sewing Machine
Bobbin/threading I have a new Singer ce-150 and I keep breaking needles. My friend says that something needs to click when I thread it and when I do the bobbin? Help me please. I really want to enjoy sewing but am not off to a great start! Julie
  • 4 Answers
Could be acouple of things. The tension on the thread or the bobbin. The needle not in all the way. Wrong type of needle for the thickness of the material. My problem was always trying to pull or push the fabric with the needle in the material - cause a bend, then the tip snags the side of the bobbin hole. Snap it's gone.
As your friend suggested, check the threading of the bobbin, the click she/he might be talking about it the first rotation of the bobbin, then being snagged by the needle thread. Good luck!
Posted on Jan 25, 2009
I have just been given a singer melodie 40.When I start to sew, material is stopped by bobbin? Bobbin is breaking off bits of thread underneath?
Try a brand new needle. Make sure the thread is suitable to the needle and fabric you are using. AVOID old or bargain bin threads. Spend an extra dollar or two for good thread.
All About Needles
Check that there are no loose threads stuck in the upper thread path, ie the tension disk.
ALWAYS RAISE the presser foot when threading the upper thread. Verify that the thread path is correct. Mis-threading will invariably cause broken thread.
Clean out the bobbin area & feed dogs of any lint and loose threads. Check that the bobbin has been installed & threaded correctly and turning the right direction in the bobbin case.
Manually rotate the handwheel one turn until the upper thread grabs the the bobbin thread. Pull it the rest of the way to the top. When beginning to stitch, start slowly and gently hold both thread tails in your left hand until it has made a couple of stitches.
How and Why to Bring up the Bobbin Thread
If you have a manual, make sure you follow the maintenance tips. If the machine needs oiling, be sure to follow the instructions using only fresh good quality sewing machine oil. Most machines that have been given as gifts from a sewist's stash may not have been maintained regularly.
If it still does not stitch properly, take it for service. It could have a timing issue, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
Singer melodie 40 user manual
Oct 25, 2016 | Singer Sewing Machines
I have a futura ce 150 and my bobbin thread won't catch
Are you able to bring the bobbin thread to the top of the needle plate, but it's skipping stitches, or you can't "catch" the bobbin thread to start sewing at all.
If you can't "catch" it at all, your machine's hook is no longer synchronizing, and you will need to have it retimed by a technician. The good news is, timing is not something that is unique per manufacturer, which means ANY sewing machine technician should be able to do it.
Sep 25, 2014 | Singer CE-100 Futura Computerized Sewing...
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
The thread and bobbin are nesting up in the bobbin case
Two things I have found that make my singer ce-200 nest. 1st. When I change threads, sometimes I thread it wrong - always nests when I do that. 2nd. When the bobbin runs out of thread it always nests for me, so I have to check the bobbin often. And I remembered a 3rd thing. 3rd. The area for the bobbin & bobbin casing has to be clean, no pieces of threads, and the bobbin casing itself can move, so make sure it's seated correctly.Whenever I get nesting, I take the metal cover off, under the needle, to get in and clean the bobbin area and under the needle good, before I go back to embroidering.
Oct 28, 2009 | Singer CE-200 Quantum Futura Computerized...
Problems with Singer CE-150... the LED light #19 keeps coming on, but I KNOW it isn't threaded incorrectly..
This machine uses a rotary thread break sensor. If you look at the top left of your machine when it is running the sensor (white dial) should be spinning. Threading around this part is critical. Make sure it spins when you pull thread through the needle. if it does not you have missed something in threading. If this is spinning and machine still stops it is likely the sensor is malfunctioning.
Mar 21, 2008 | Singer CE-200 Quantum Futura Computerized...
The thread keeps breakijng when I am embroidering
It could just be that your needle is blunt and you need to put a new one in. It is amazing how many different problems a blunt needle can cause. Hope its sorted now.
From Sewmad
Nov 04, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-100 Futura Computerized Sewing Machine Logo
174 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
