Question about Grundfos Pumps Grundfos SQFlex Solar Submersible Pump 6-SQF-3
Grundfus solar submersible pump sqflex cu 200 is not pumping and shows a f3 single
What Do Customers Expect While Taking Submersible Well Pump Conroe TX Service?
Any submersible well pump service is usually aware of the concerns a person suffers when his family relies on water well. From Submersible Well Pump Waller TX service in Texas, clients expect that the well pump service is made available in least time, maintaining costs to be low and minimum turnaround times. The clients expect single stage pumps which can be utilized for sewage pumping, drainage, slurry pumping and general industrial pumping. Customers also expect that the cable required for this kind of application should be durable and trustworthy because the installation location as well as the environment can be very restrictive along with being hostile.
Mar 11, 2018 | Plumbing
Where can I get repair parts for a Grundfos CU 200 solar controller?
Sorry we have no parts resources other than what you can find on the web.
Jun 23, 2016 | Grundfos Pumps Grundfos Smart Box...
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
How much solar panel watts will it take to run a 130 volt 1 hp water pump?
Does the pump have a current quanity amount on it. If it does multiple this with 130 and you should get the power needed.
Sep 19, 2014 | Garden
My grundfos200 sqflex displays a couple of dashs and a 3. What is wrong?
check that the impellor is not seized or that there is not water in the motor.
Sep 08, 2014 | Cars & Trucks
Why does Grundfus bell pump dry runs won't turn off?
If you have a switch of some sort to tell the pump the house needs water, look there first.
Aug 29, 2014 | Plumbing
Submersible pump with only two wires going to the motor. how do i connect it to the control box?
Brown wire should be active and blue should be neutral. the motor will still spin the correct direction as it is single phase . Have a look in the connector box and which ever wire is connected to the active then that will be the wire for the motor.
Mar 23, 2013 | Submersible Systems 1/2HP 2WIRE...
Hi i looking for water pump 10hp single phase borehole 150feet under ground 1500gpm submersible please can you rang run on single-phase 240v thanks harry 00353860818018
Don't knw what your problem is but here is a page that gives you the information, normally 3 phase on single phase motor but if you can change the winding settings you might here is the page hope it helps.
http://www.pentairpool.com/pdfs/CSeriesCommercialBronzePumpOM.pdf
Dec 20, 2010 | Pentair 10hp 3ph Single Phase 220440v 60...
Grundfos submersible well pump with Grundfos CU301 control. Control box shows no contact to pump. What is the problem or problems?
Grundfos is a p. o. s. I have a new system cu 301 and I have had to get it repaired twice by Fogle Pump and Supply. These guys are real rip of artists in Washington State and should be reported to the BBB. Dont Use Fogle if you need a well
Sep 15, 2010 | Grundfos RCP-96 Recirculation Pump for...
Grundfos Pumps Grundfos SQFlex Solar Submersible Pump 6-SQF-3 Logo
61 people viewed this question
Top Grundfos Pumps Electronics - Others Experts
Are you a Grundfos Pumps Electronics - Other Expert? Answer questions, earn points and help others
