Question about OKI MICROLINE 320 Turbo Matrix Printer
The oki data problem spewing jibberish
I've unhooked the parallel cable, disconnected power etc. so far . . no good. Still spewing.
  • Gary
    Gary May 11, 2010
    So, am I to understand that garbage prints out, even when the parallel cable is unplugged, or just when you try to print to the printer from a PC?
I USE 3-PART PAPER AND THE SECOND AND THIRD COPY AREFAINT AND HARD TO READ. THE TOP COPY IS FINE. HOW CAN I FIX THIS?
Posted on Feb 02, 2010
OKI Error 0002
OKI error 002 is a main engine board failure. sometimes this can be caused by bad data received from the PC.
remove all cables from printer and only leave power on. run internal pages and if it works then most likley case is the bad data from USB/netowrk
Aug 25, 2014 | OKI B4350 Laser Printer
HP LaserJet P3005 Printer will not print using a parallel cable.
# Switch off the printer, cancel pending jobs..Refix parallel cable both ends & tighten them Check proper drivers installed or not if not install proper drivers.. shoot print command. check..if not resolved...For tech guys:# Replace cable..checkRemove printer formatter, check any dry solder or pin breakage at parallel port.(show in snap shot), found... try to repair it or replace the formatter assm. Check system parallel port working or not...
Dec 30, 2011 | HP LaserJet P3005 Printer
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
Battery wiring
Series or paralell?. Should be parallel so you get 12 v0lts. two positives together and two negatives together
Sep 26, 2009 | 2001 Toyota Land Cruiser
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Abnormal printing with continuous tone
this sounds like it is doing something called a "hex dump" basicaly printing all ASCII characters. okis tend to do this from time to time if l;eft on for a significant period with no data sent to it. the only advice given by oki is to switch it off when not using it unfortunatly Hope this helps Cops Pete@wedotoners.com
Oct 08, 2007 | OKI Pacemark 4410 Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
146 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
