Question about Hotpoint Refrigerators
HSS25GFTG WW WATER DISPENSER NOT WORKING
larryyb
  • 291 Answers
SOURCE: GE gss25ifrf ww Ice maker
you will need to replace the dispensor board part number WR55X10444
Posted on Dec 04, 2008
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
nnesmith
  • 162 Answers
SOURCE: GE Fridge - model gss25tgma ww - will not dispense water. Ice
solution part # wr49x10173. door heater. comes with instruction. install in 15 min. good luck.
Posted on Jan 19, 2010
iwillfixforu
  • 619 Answers
SOURCE: I have a GE Refrigerator GSS22JFMD WW with a ice
The water supply in the recessed part of your door is frozen. very common with this model. You will need to turn unit off and with freezer door open use hairdryer on the area where water dispenses and on the recessed area as well. This is time consuming but only other remedy is to leave off and door open for 24 hours. hope this helps.
Posted on Feb 23, 2010
  • 3 Answers
SOURCE: Hotpoint ice/water dispenser will dispense ice but not water
You may have a blocked filter. Has this even been changed since you have hook-up the water line, or did you recently just install a new filter. If so it may not be in right correctly. try removing it and reinstalling it.
Posted on Mar 13, 2010
Refrigerator GE SXS water dispenser works intermittently, ice etc works fine
I believe that you likely have a defective dispenser switch located at part location #72 in photo=> HERE This is that part number=> WR23X10224 Micro Switch I'm here should you have question, Thanks, Sea Breeze
Oct 06, 2015 | GE Refrigerators
How do you get the water dispenser on a GE side by side model GSS201EPD WW to work?
Chances are that the=> WR57X10050 Water Inlet Valve has become defective on the dispenser side of the valve.. I am here should you have questions, Thanks John T. Appliance 911
Jun 28, 2015 | GE Refrigerators
GE refrigerator/model GSS201EPH WW. Water dispenser works fine, ice dispenser does not work
there is a pump which pushes water up to ice maker, it usually quits, causes the prob. 90% time
Jul 17, 2011 | GE Refrigerators
Mar 13, 2010 | Hotpoint HSS25GFP Side by Side...
Feb 12, 2010 | GE Refrigerators
Jan 19, 2010 | GE GSS25TGMCC / GSS25TGMWW Side by Side...
We have a Hotpoint side by side fridge. It always makes
check the door in the dispenser if moisture is condensing and freezing so that the door won't open try manually popping the door open just before you attempt to dispense ice, maybe you'll get lucky, otherwise your going to have to get a technician to come and check the micro-switch for the dispenser
Dec 05, 2009 | Refrigerators
No water at dispenser
apply hair drier to spout and surrounding area for a minute every ten minutes , after about an hour the ice that has formed will be loose enough for the water to come out of spout
Mar 28, 2009 | Hotpoint HSS25GFP Side by Side...
Refrigerator will not dispense ice or water.
I have one the same model It done that about a month after I got it.
1995 Year I took of the left top corner the wires that make it work are in it. I wiggeled the wires around untill it started working and folded a card broad and put in it to hold the wires the way I wanted then put the cover back still works to this day.
Worked for me, Thank You,
Sep 02, 2008 | GE Refrigerators
Water leaking out of freezer door water dispenser
The fill valve that supplies the water may not be shutting off completely. Also check to see that the lever is closing completely.
Apr 04, 2007 | GE GSS20IEP Side by Side Refrigerator
Refrigerators Logo
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
