Question about Peg Perego Vespa Scooter
Vespa P150X Piaggio won't start
We have a Vespa P150X (1978) that has run like true love until last week. We kick started it and it started immediately, but we let it die before it was idling properly; after that ... well, it wouldn't start. We tried everything, from checking and changing the spark plugs, checking the fuel flow, the points - and all seems fine. But, no matter what we do - it just won't start. It sounds like it wants to ... to the point that it even backfires - but nothing. Any suggestions?
  • Peg Perego Master
  • 706 Answers
I think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new oneVespa P150X Piaggio won't start - vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Posted on Nov 29, 2014
5 Suggested Answers
  • 5 Answers
SOURCE: vespa cutting out after around 40secs of running
getting to much fuel apparently.But have never seen or heard of one of these.
Posted on Dec 23, 2008
  • 32 Answers
SOURCE: Fuel Starvation Problem
Try taking off the fuel line from the tank to the carb and blowing through it
Posted on Aug 03, 2009
  • 32 Answers
SOURCE: trouble starting my vespa
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
  • 87 Answers
SOURCE: vespa starting problem[smallframe douglas 90cc]
did ya rebuild the carb or not sounds like the carb got ear wax in it
Posted on Aug 04, 2009
My vespa piaggio 125 seizes up when turning over after about three times same on kick start help pls
Hi, Mark the answer to this question is way above my pay grade and for this situation, I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Seized Engine
Struggles to turn over and wont start with new battery in need of some...
Piaggio Fly 150 4T Workshop Manual
https://www.oemmotorparts.com/oem2.asp?M=piaggio
PIAGGIO Beverly 125 User Manual
May 01, 2017 | Piaggio Motorcycles
2007 Piaggio Fly 50 intermittent hard starting
Hi, Anonymous and the usual suspects are:
1. Spark plugs in bad condition or have an improper gap or are partially fouled.
2. Spark plug cables in bad condition.
3. Battery damaged or nearly discharged, should have 12.5 volts.
4. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Throttle controls not adjusted correctly.
6. Water or dirt in the fuel system.
7. Water or dirt in the carburetor.
8. Faulty fuel pump.
9. Intake air leak.
10. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricting fuel flow.
11. Enricher valve inoperative.
12. Engine lubricant to heavy (winter operation).
13. Ignition is not functioning properly (possible sensor failure).
14. Faulty ignition coil.
15. Valves sticking.
Modern Vespa Piaggio Fly 50 with intermittent starting problem
My Piaggio 50 Won start
PIAGGIO MSS Fly 50 4T Workshop Manual
Piaggio Fly 50 4T 2005 2012
http://mybikemanuals.com/vespa/uncategorized-vespa-owners-manuals
May 23, 2017 | 2007 Piaggio Fly 50
Piaggio mp3 125cc motorcycle, won't start and emits high-pitched "whining" noise, last garage-serviced October 2012
chec alternator for health--sounds like bearings are bad--du u gut a repair book for that model--git one online or checout library sec 629--its a basic component so othr manual can help u
Feb 25, 2013 | Piaggio Motorcycles
My 2000 Vespa et150 won't start. Battery is fully
try jump starting as well as checking you connections
Sep 17, 2012 | Cars & Trucks
I have just bought a 1978 Vespa 125 px I can't get leaded petrol what can I use ?
All Vespa's old or new run without need of lead as your engine internals are lubricated by either the gear oil or 2 stroke oil.
Jul 18, 2012 | Peg Perego Vespa Scooter
Gas overfill - Vespa LX50 won't start
It is unlikely that being unable to start is caused by overfilling the tank.
Remove the spark plug, clean it with a wire brush, and check for a spark. Turn the ignition on, put the spark plug and lead attached against the cylinder head and kick it over. You should have a fat blue spark under the electrode. Check the gap and replace the plug.
Another thing you can check for is either a pinch or an airlock in the fuel line to the carburetor.
Jul 30, 2017 | Sport & Outdoor - Others
I have a 09 Piaggio Fly 50. When I bought it, the battery was run down from lack of use and extreme cold (I used to live in the Rockies). I could never start it from the starter button, but always with a...
Hi, Jkranowitz before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
How to Troubleshoot Your Piaggio
2009 Piaggio Fly 50
http://motorscooterguide.net/Piaggio/Fly_Series/Fly-50-and-150.html
Apr 12, 2017 | 2011 Piaggio Fly 50
Need a user manual for a Vespa P150X
Hi! ScooterHelp has a very good archive of Vespa and Lambretta manuals. For your Vespa P150x you can download it here: http://www.scooterhelp.com/serial/service.VNX1T.VSX1T.html
Hope this helps, regards!
Feb 21, 2011 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
266 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
