Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
T.V. has had problems turning on for a while, now wont turn on
37MF231D T.V. little over a year old, out of warranty will not turn on...green light continously blinks, but no power...would like to know if instead of purchasing a new power control board for hundreds of dollars (given the warranty is up of course), could the power source be fixed on the old power board...if so what parts do i need to replace (model numbers) and voltages needed to upgrade so it will not burn out again...Given the money spent on a T.V. the life span should be more than a year...any suggestions would be appreciated.(before the super bowl please)LOL
Thanks in advance
frustratedtvowner
  • 90 Answers
You dont need to buy a new board they cost about 300-400 dollars--- they have refurbished boards around 100 -- look online at
partsstore.com
Posted on Feb 24, 2009
RCA 32 Smart Tv SLD32A30RQ Will turn but nothing happens and has a blank screen.
It sounds like the internal calendar function is working perfectly.
Nov 12, 2015 | RCA Televison & Video
On my Magnavox 37mf231d tv when I turn it on, the backlights turn on for about 3-4 seconds, then turns off. There is no blinking green light, there is no green light at all. It seems like it is trying
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Aug 23, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37mf231d will not turn on, only have steady flashing led light-continuous
I just fixed mine that had a very similar symptom to this and it was a bad part on the main board. I made a video showing what part and how to replace it. I also added a link below to the part I ordered. L5973D STMicroelectronics Mouser
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Magnavox 37" model 37mf231d-37 wont tun on when i hit power button the screen lights up for a secongd and turns right back to black and the power button green light comes on and right back off I found
Your power supply is weak. If you think you can repair this I will tell you how. If you cannot do this,find someone who works electronics and share this repair. Two capacitors are bad. When pulling the back cover off, you may see one or two capacitors bulged. Even if they look good....replace these capacitors. The locations are numbered and, the capacitor having a value and temperature of 105 degrees.. Location of the first capacitor is 2074, value 25volts @ 2200 mf @ 105 degrees and will most certainly be bulged. The next capacitor may look fine....replace it. That capacitor location is 2066, value is 35 volts @ 1200mf @ 105 degrees. When you replace these, please be sure to get the polarity (positive leg and negative leg) of these capacitors seated correctly...this is a must. This will correct your TV. You will save lots of money, because you asked. Thanks for listening ..good luck...we will be here for your next repair.
Jan 02, 2013 | Toymax Magnavox 37MF231D 37 in. LCD TV
Vizio wont turn on!!
I have this problem. Bought at Costco. Called them and was transferred to Vizio. TV still under warranty, so they are supposed to get me another TV. Mine is only a little over a year old. The one they are giving me is NOT new, but refurbished. I'm not happy about this, but what can I do? Apparently, this IS a KNOWN problem.
Aug 05, 2009 | Vizio L37 Television
Kodak Easy Share Z1275 stuck lens
**** a very common problem with most cameras. There hasn't been much of a solution for this problem except to try to wiggle the lens zoom while pushing and holding the power button.
Also make sure you have brand new batteries installed. Even the slightest dead battery will cause a problem.
Jun 02, 2009 | Kodak EasyShare Z1275 Digital Camera
My elit comes on and the light is on but it wont start.
check your dic is there a ring on it if so contact me:dracohackess@yahoo.com
Dec 26, 2008 | Microsoft Xbox 360 Elite Console
Wont turn on
Most common problem is a ruptured capacitor on the main power pcb. It can be seen as ruptured if you know where to look. It has to be replaced with a special type of capacitor or it will quickly fail again. If its less than a year old it is still on parts warranty.
Sep 29, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
RE: MY TV WONT COME ON ???????
Yes the light with the sun around it, as you discribed it, is the light that tells you the bulb is out. Your set uses a Sony part number XL-2100U bulb abd that is available HERE http://www.partstore.com/PartSearch.aspx?PartNumber=XL-2100U&x=15&y=18 I would go for the first one, as I have found replacements for a little less cash just do not woirk the same and do not last the same. Good Luck
Jul 29, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
140 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
