Question about MyMusix PD-6030 MP3 Player
MyMusix PD-6030 MP3 Player reset - MyMusix PD-6030 MP3 Player
SOURCE: MyMusix PD-6110 MP3 Player
When you hook it up, you should see an icon on your computer for the MP3 player.
I download songs from iTunes to my MAC, then drag them to the MP3 player. However, they do not come from i'Tunes in a MP3 format. I found this on the internet for how to change the format:
When iTunes is open, find "preferences" and then locate "importing" (just look around on the different tabs till you find these, since Mac and Windows put them in different spots) tell it to import using MP3 encoder from the drop down bars, and say OK. now you can right click on the song you want to convert and select "convert to mp3".
Then drag the MP3 song to the MYMusix player icon and it should copy the song.
Posted on Jan 02, 2008
SOURCE: mymusix (PD 135-02) 1GB MP3 player files not recognized by my computer
MyMusix MP3 Player PD-6110 doesn't show up on my computer. I'm using Windows 98SE and downloaded the driver I needed but I still can't find this device.
Posted on Jan 05, 2008
Robocody
SOURCE: mymusix PD-6070 mp3 player wont work
You all Have 12 month warranties from MyMusix, if you bought it at radioshack. Go to Mymusix.com or Email: Support(at)Mymusix(dot)com.
As long as there is no physical damage, they will fix it. You have to be persistant, though. And if you don't have your receipt... Go to the radioshack you bought your player at and ask them to print you another one... They'll need your name, zip code, what player you bought, and the year of purchase... and then they can print you another.
-Cody
Posted on Mar 12, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: what is a I/O error
Start --> Control Panel --> Printers and Other Hardware --> System --> Hardware --> device Manager - see if there are any yellow exclamation marks by the player and follow Windows troubleshooting
If the fails, you will need to restore the player's firmware - the instructions are too long to post here, but they can be found at www.mymusix.com on their pd-6030 page - click-by-click with pictures - very detailed.
-Tha Mp3 Doctor
Posted on Jun 14, 2008
SOURCE: MyMusix PD-6030 MP3 Player says license expired
Are the files MP3 files or WMA files? This sounds like a DRM (digital rights management) limitation of the music you are using. MP3 files don't have DRM - and shouldn't exhibit this problem. WMA files can have licenses associated with them and only allow number of copies to be made for personal use before their license disables further use - as it sounds is occurring in your case.
Posted on Aug 05, 2008
Requesting manual
Go to this website, they will have your manual to download in PDF format. Good Luck, I hope this helped. Please Rate me, Thank You
http://www.retrevo.com/r/23015bh837/1/pdf#q=MyMusix+PD-6030
Dec 12, 2009 | MyMusix PD-6030 MP3 Player
Flash error backup data and format
just connect it to the computer then save all ur folders to ur desktop thats the easy way to back up data
May 15, 2009 | MyMusix PD-6030 MP3 Player
Jul 17, 2008 | MyMusix PD-6030 MP3 Player
My mp3 player wont turn on
This might be a tricky one to solve - may take more than one method.
Start by resetting the player. Then replugging it into the computer.
If it still fails:
Uninstall the PD-6030 via device manager. The PD-6030 needs to plugged in to do this. Go to Start, Control Panel and select 'Performance an Maintenance'. Then Select 'System'. Then select the 'Hardware Tab' and select 'Device Manager'. Then find a device called 'Portable Devices' or 'Windows Portable Device'. Then select the + sign next to the device and right click the 'Audio Player'. Select 'Uninstall'. Click 'OK' when it asks you if it is OK to uninstall. Then select 'Action' at the top of the Window and select 'Scan for hardware changes'. Then once it re-installs the driver, see it operates
correctly. Also, performing a firmware recovery procedure can work to make your computer recognize the PD-6030. Please follow the set of instructions titled, "Q: How to recover my player's firmware?".
The firmware upgrade can be found at www.mymusix.com
-Tha Mp3 Doctor
Jun 13, 2008 | MyMusix PD-6030 MP3 Player
What is a I/O error
-Tha Mp3 Doctor
Jun 05, 2008 | MyMusix PD-6030 MP3 Player
I need help
the request could not be performed because of an I/O device error.
Mar 18, 2008 | MyMusix PD-6030 MP3 Player
Mymusix pd-6030 player
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to www.mymusix.com to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Nov 29, 2007 | MyMusix PD-6030 MP3 Player
Flash error
same here just a diff mp3 ...
Nov 25, 2007 | MyMusix PD-6030 MP3 Player
PD-6030 MP3 player flash error message
MyMusix's PD-6030:
If that fails,
If that fails,
-Tha Mp3 Doctor
Nov 08, 2007 | MyMusix PD-6030 MP3 Player
PD-6030 MP3 Voice recording distortion
MyMusix's PD-6030:
Manual can be found at www.mymusix.com
EQ setting
Select from "Normal, Rock, Jazz, Pop, Classic, Bass" .
You can also select "Exit" to keep the original settings.
Menu Tree Diagram is on p.29
For "password" question - there is no password, the lock on the player has simply been engaged - slide it to the unlocked position. See manual for details.
-Tha Mp3 Doctor
Nov 05, 2007 | MyMusix PD-6030 MP3 Player
MyMusix PD-6030 MP3 Player Logo
24 people viewed this question
Top MyMusix Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MyMusix Audio Player and Recorder Expert? Answer questions, earn points and help others
