Question about Dyson DC25 Ball Cleaner Head, or Power Nozzle. Part 915499-02
Brush not spinning
Suction is fine, but no power to the pwer head
  • 175 Answers
SOURCE: My dyson DC07 has no suction. motor runs, brush
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
kindly rate my response..
Posted on Jun 10, 2009
  • 7 Answers
SOURCE: Dyson DC7 full Kit, with one belt does not get suction to head.
I took the pre filter out of my dyson it now sucks wonderfully By the way mine wont **** at all with brand new clean prefilter it mine is a dyson animal .My other dyson is the yellow one that works with prefilter in no onw has been able to make my sco7 animal one work with filter in strange
Posted on Jul 26, 2009
  • 8404 Answers
SOURCE: brush doesn't spin and there is no suction there
Check for clog in the hose or what ever connects the nozzel to the collection device. I pick up vaccum cleaners all summer, most new, all clogged, all from the trash.
If possible, take the machine outside, open the collection device, run the motor. Is there suction you can detect anywhere?
Posted on Sep 07, 2009
capsman
  • 111 Answers
SOURCE: The main brush will not spin
I would guess the belt is broken. That happens often. Get a correct belt. Remove the brush roller. Wrap the belt around the roller and drive peg. Reasemble -- easier said than done, but keep trying.
Posted on Sep 27, 2009
Vac Belts
  • 701 Answers
SOURCE: The brushes are not spinning.
Your belt has probably broken. Here is a link to the belt you need:
Dyson DC17 Belt
And here is instructions on how to change it:
1. Loosen 3 screws from bottom plate using flathead screwdriver or coin edge and remove it.
2. Wiggle roller until it pulls straight out.
3. Squeeze new belt and loop it over metal drive gear (you'll easily see the gear).
4. Keeping belt on gear, insert edge of roller through belt and rotate the roller while pushing it through belt until it is inside the belt, then continue rotating roller and sliding it over until belt is in position over gears on roller.
5. Insert roller into slots on that it came out of, reattach bottom cover and its done.
Posted on Nov 28, 2009
Why aren't brushes spinning?
Belt misalignment sounds like the problem
Mar 31, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
No power to cleaning head
It'll help if you clarify if this is no power at all - the motor makes no sound, motor is on but no suction, and/or suction but the brush isn't spinning. If the latter, then there are a couple of possibilities. The bar should stop spinning when full upright, where the system will route suction to the handle for accessories. Try reclining the handle. there is also a switch for the brush clutch to engage (see the manual
http://www.dyson.com/medialibrary/files/dyson/support/downloads/uk/floorcare/manuals/DC25_Manual.pdf ), including page 8. The brush will also stop if there is a blockage.The checklist for clearing obstructions and resetting the brush bar (!) are shown on page 5 - there's a switch on the back to press twice, probably re-engaging a breaker.
Good Luck!
Jul 19, 2014 | Dyson DC25 All Floors Bagless Upright...
My Power head on my Dyson Animal DC39 will not stay spinning. Suction Issue?
There should be a red insert on the right-hand side on the cylindrical bulge behind the brush cylinder. Check that this is moving when you push the button. The red insert should stay pushed in for the brush to rotate. The insert moves in an out as well as rotates in order to lock in the 'in' position. Mine is a little sticky on the rotation and I need to shake the brush head a little in order to get it to rotate and lock.
Jan 05, 2013 | Dyson DC39 Animal Canister Vacuum
Miele, Flamenco II. 2 probs. 1. the head brush is not turning when I put it on the floor. If I pick it up to look inside...the brush is spinning fast..I put it down on the floor...the head does not...
sounds like the belt is not on correctly on the beater brush or the belt is worned out now for the suction check filters or bags that need to be empty or clean
Feb 16, 2011 | Miele Vacuums
The machine will not suction - it will spray and spin the brushes but will not suction - the power is going to the machine, but it will not suction.
Disconnect the suction hose. While running, check the suction port if it works, by putting a piece of paper. If the paper is taken in, then it is oK. Now, check the suction Hose for breaks or opening before the suction head. Breaks or opening breaks the suction power at the suction head. Loose connection between the suction pipe and the suction port also must be check as this will also cause the same
problem. You may need to replace the suction hose
to correct this problem,
Send us the e-mail and your vote if this solves your problem.
Sep 27, 2009 | Eureka Atlantis 2590A Wet/Dry Vacuum
Brush spin,good suction at hose, no suction at
Air passage from back of brush head, through the joint, and up to bag, may be blocked.
Jul 11, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Power head on epic 6500 does not work, is there a belt?
This is a bot of a blind guess, I don't know the model. But most power head cleaners I have worked on use the suction of the vaccuum to spin a turbo fan in the head (like blowing a child's windmill). The head not spinning is usually because there's not enough **** to spin the turbo fan. Check for:
Gummed up brush bearings (dirt or damp) making the brush harder to turn than it should be.
Poor suction caused by a blocked or partially blocked pipe.
An obstruction that is tactchin the beater or the turbo fan.
Blocked filters on the cleaner, reducing the **** and thereby not providing enough vaccuum to spin the beater.
Jan 18, 2009 | Electrolux Epic 6500 Vacuum
Dyson DC25 Ball Cleaner Head, or Power Nozzle. Part 915499-02 Logo
15 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
