Flashing EE:EE on airconditioner wall control
The air conditioner wall control is flashing EE:EE and is not cooling well. it begins to feel cool, then the e's appear and then it just blows air, no cooling. i have removed the filter (very clogged) and cleaned it still nothing. The main unit is on the buildings roof so i dont know what the brand is, and its an older unit (8-10yrs) with no brand on the control.
    Problem Solver:
  • 10 Answers
Your system might need reseting look for a reset switch on your thermostat or your inside unit usually means dirty filter
Posted on Jan 04, 2013
  • 154 Answers
SOURCE: older roof mount RV Colman Air Conditioner on a 1989 Motorhome(class C)
It depends how old it is most can be regased but about 15 or so years ago they changed refrigerant gases because the old one was killing the ozone if not that old you should have no problems with regasing it just make sure they check for gas leaks first which is a small amount of dye put in the gas so you can see the leak. Hope this helps
Posted on Jul 22, 2008
  • 400 Answers
SOURCE: LG Room Air Conditioner Model
I would say that your return air sensor is faulty or not positioned correctly. Check sensor
Posted on Mar 05, 2009
louislevel_2
  • 374 Answers
SOURCE: Heil airconditioner is not cooling? Heater works
If no blowing air is coming out to your ac or evaporator fin,your blowing fan is not working.There are several factor to check qualified electrician or ac techician should do this.If you have knowledge on electricity and motor control,beside you should have clamp ammeter to use in trouble shooting of ac electrical circuit.Unplug your ac If there is an opening of blower fan of your ac mostly the top cover open this one locate the wire connection of blowing fan take the color and size.Open the terminal box below the control panel of ac and locate the wire of blowing fan.Check how many leads make sure to make sketch where it was connected from low,medium, and high there is coded color on it,discannect from the terminal, using clamp ammeter set to ohms probe setting R10 check continuinity of winding motor start at common lines(mostly balck color) of one test rod and the other to starting line(mostly red color)take and read the resistance if has a higher resistance your motor is burn out, also with the running line w/c has multple line for speed.If resistance complied to your motor rating or good,If not or burn out replace fun motor.Check your capacitor,doing this set your ohmeter to a higher resistance,connect one red test rod (+) one terminal of capacitor and one black test rod on (-)the other terminal the pointer will deflect steady to higher resistance then reverse the connection of the test rod,the pointer deflect again to higest resistance it will go slow backward setting to zero if you got this result your capacitor is good.But if it does not go set back to zero your capacitor is short.Replaced capaciter.
Posted on Mar 13, 2009
TheMobilian
  • 8220 Answers
SOURCE: Hampton Bay air conditioner wall unit doesn't cool
Might be the CAPACITOR
Posted on Jul 01, 2009
  • 232 Answers
SOURCE: "cool on " flashing..no heat or cool air blowing
when its flashing its in a 5 min delay mode if you wait 5 min and still flashing you may need a new stat. but give it a full 5 min.
Posted on Sep 20, 2009
Whirlpool gbd307prb01
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Sep 22, 2011 | Haier HWR06XC6 Wall/Window Air Conditioner
It doesn't take the humidity out of the air. It alsocausesdampness in the air and cloth furniture, etc. When I first bought the airconditioner it removed the humiidity and cooled my apartment just fine...
heatman101
Aug 27, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Air is cold but hardly blowing
heatman101
Aug 21, 2011 | Fedders A6D24E7D Wall/Window Air...
Please help carrier 38ck03040 outside unit hums but not cooling....top of unit feels hot
heatman101
Jun 25, 2011 | Carrier 38CKC042 Air Conditioner
My air conditiner does not want to turn on.
heatman101
May 31, 2011 | LG Goldstar GWHD5000 wall/window Air...
Not cooling
you may be low on refigerant
Jun 27, 2010 | Hampton Bay HBLG5004 Air Conditioner
My GE wall Airconditioner is not cooling brings out warm air?
mcdevito75, here, wall A/C do they also give out Heat, if so, refer to the owners manual for instructions on how to use the cooling. Set switch to low cool and the switch with the blue scale about 1/2 way thru the blue scale shown on the switch (Knob) Both your A/C units may be set on heat, double check position on switches, (Knobs)
Jun 24, 2010 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
140 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
