Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My menu displays pops in and out on my screen. Sometimes it last
For 2 mintues. How can i stop my menu from displaying on the screen by itself?
  • 147 Answers
The menu button on the front of the set has to be replaced but this is not an easy job.
Posted on Jan 19, 2009
Shower water stops by itself
By the model I am assuming this is a shower head?
You may have to try pulling the shower head off to see why it is turning off such as something clogging it up, ect.
Oct 28, 2012 | Home
Display continueuly changes
Unplug your device for about 30 minutes to let the circuitry reset itself.
If it works normally after that, it means a hardware part(s) is overheating inside, more likely a power supply is starting to fail and does not provide the proper voltages for the microprocessor.
Jul 04, 2008 | Dell W2300 23 in. HD-Ready LCD Television
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
I am having 2 issues. Most importantly, my front load washer/dryer is skipping drying time. I typically wash the clothes then put dryer sheets in and use the dry only on low heat option. It starts...
Your two issues may be related. A combo washer / dryer uses a fine spray of cool water to condense moisture out of the air stream while drying. This water is then pumped down the drain. Cold water is also used to fill the softner dispenser. If the inlet screen on the cold water connection to the machine is restricted, those are two of several things which could show up. Turn cold water valve supplying water to machine off. Unscrew cold water fill hose from machine. Remove screen from inside machine, clean, re-install, re-attach cold water fill hose, turn cold water valve back on and see if performace improved.
Mar 02, 2011 | LG WM3431 Front Load Washer / Dryer
I have an LG rumour phone - just about an hour ago the display disappeared and it shows only a white screen with a leat in the bottom right hand corner. Can anyone help me? There is still sound - it...
Remove battery out of the set and keep aside for sometime- 15 mintues or more.Now replace the battery back after removing the memory card , if the display does not come back then
You can have a faulty display, display connection or an errors in the motherboard, can be software or hardware.
Sep 24, 2010 | LG Shine KE970 Cellular Phone
I have a Sony WEGA KDF-E60A20 for 4-5 years. A few mintues after i turned it on, the screen goes blank with no sound. It comes back after 1-2 minutes. It goes blank again after 2-3 mintues. It just keeps...
It's the lamp. I do have an article on this in my Tips & Tricks regarding lamps, but replacing the lamp is a sure fix. I hope this was helpful, best wishes.
Apr 29, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen displays not available eventhough the video
The main board has become faulty. The logic in the TV is bad that is causing the TV to have such problems. The only way to fix is to replace the main board.
Nov 08, 2009 | Toshiba 37AV502U 37 in. LCD HDTV
My tv turns blue and turns itself off
optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Jul 12, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
Mar 15, 2009 | Sony Car Audio & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
52 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
