Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
How to take front off frigidaire model fex831fs4
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: How to remove the front washer panell on Frigidare
There are two screws at the bottom you remove and then the front will slide up 1/2 inch or so unlocking the tabs on the side and you can pull the front off. There is a guide pin in the top to help align it when you put it back together. Here is a DIAGRAM which might help.
Posted on Jan 18, 2011
I need help replacing the thermal limiter in my stacked Frigidaire FEX831FS4. I know where it is, but I don't know how to get to it. Cherish
Go to www.repairclinic.com and enter FEX831FS4. You will be presented with a list of common repair parts and may be able to view a video showing disassembly and location of the thermal limiter.
Oct 18, 2016 | Frigidaire Dryers
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
HOW DO I CHANGE THE HEATING ELEMENT IN MY FRIGIDAIRE LAUNDRY CENTER FEX831FS4
Good afternoon Jerry, thank you for your post!
I understand that you are attempting to change the heating element inside your Frigidaire laundry center, FEX831FS4. These intricate parts do require precision and patience, therefore when replacing the exchange of electrical components or removing them from your appliance, I always suggest seeking professional assistance. One must be very careful as these replacements can lead to potential harm. -Matt
Aug 19, 2014 | Frigidaire Washing Machines
How Do I replace the Timer on a fex831fs4?
U CAN ACCESS FROM BEHIND BUT BE SURE AND REMOVE CAP AND CONNECTOR AT FRONT
Jun 01, 2014 | Estate TAWX700JQ Top Load Washer
I have a FEX831FS4 that will not agitate, however, it will drain and spin. Where should I start the diagnosis process?
Start right here:
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Washer-dryer-combo-Parts/Model-FEX831CS0/1428/0152000/R0310016/00005?blt=06&prst=&shdMod=
This will give you a good idea of what you are looking at and where it is located as-well-as the expected costs of parts. Keep in mind though eBay is now a great place to get parts. Often for way cheaper than a parts outlet will charge.
It's kind of unusual for a machine to just lose agitation, unless it has a clutch or maybe agitating dogs; however, this unit has neither that i see and i must confess i've never worked on one. It's possible #2 on the transmission diagram is worn. Does the agitator spin? It may turn a little, but should not spin around like there is nothing holding it. If it does it is either the agitator or the part it connects to (# 2) or an associated part. Removing agitators can sometimes be a pain. Warming an agitator up with a hair dryer can make all the difference in the world when something seems stuck.
Good Luck.
Jan 07, 2013 | Frigidaire FEX831CS Top Load Stacked...
I have a FEX831FS4 washer/dryer. The washing machine will wash and spin, but will not rinse and spin. Lid is locked.
think ur voltage is too low..usually frigidaire brand washer is 220v,..usually starting of spinning has a high ampere and it need a high volt electrical supply..try to check ur main breaker for washer only..ur lid lock will lock after 10secs when it spin fast...
Dec 02, 2012 | Washing Machines
Getting beeping sound from door lock switch unit stops running on a fex831fs4
Hello acedel72 - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Unit could possibly be experiencing a communication issue with the control panel, faulty door lock switch or wiring failure which would need further diagnosing.
Nov 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire model fex831fs4 will not drain or spin
My problem was a little different but I want to post this for others that might experience the same.
My Frigidaire Washer/Dryer Stack Combo Model FEX831FS4 was not draining and had a humming/buzzing noise when it got to drain/rinse cycle. This is usually and probably caused by a small sock or thin or small underwear that got sucked out the top and into the drain hose. I have no idea why they did not design this with a rubber flap like most washers to protect from items going up and out but here's how you fix it.
IF your unit is having this issue STOP and don't try runnin drain/rinse cylces anymore or you may damage the water pump and have to buy a new one. I think I damaged mine from trying to drain the water so many times with a sock clogged in there... but so far it is working anyway, just with a buzzing noise.
HERES THE FIX
You need to TAKE OFF the FRONT COVER and REMOVE the ITEMS FROM the HOSE leading to the WATER PUMP. The water pump is on the bottom front left and theres only TWO SCREWS to get off the FRONT COVER of the washer/dryer. They are on the bottom by the feet. Have someone tilt the unit backwards and unscrew them with a phillips head and then pull the front cover down and off. There is a rubber snap pin in the top center of the cover but it will come loose as you pull down.
In order to get at the water pump you do NOT need to pull the washer/dryer out, you can get at everything from the front. However it might be a wise decision to unplug the power since water will be draining everywhere.
First siphon out all the water in the tub, whatever you don't siphon will immediately coming rushing out once you remove the hose from the water pump.
I would UNPLUG the electrical connector on that water pump and tie it up out of the way because even if you siphoned the water there will still be water in the hoses and probably under the washer tub some.
Disconnect the hose that comes from the tub to the water pump. That's where I found a small children's sock clogging the pump. Dry off the water pump plug connector pins if they got wet (where you removed the plug from) and reconnect the electric connector.
We tried many times to run the drain cycle before taking the washer/dryer apart so your water pump might be shot as I think mine is. Now mine always makes a buzzing noise as if it's wore out from being worked with a sock blocking it's inner part. You might need to replace your water pump.
May 08, 2012 | Frigidaire FEX831F Top Load Stacked Washer...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
19 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
