Question about Broan-NuTone VX475 Bagged Central System Vacuum
Nutone vx550cc shuts down - Broan-NuTone VX475 Bagged Central System Vacuum
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
My VX550CC also shuts down after about 15-20 minutes. My problem is that I can't find my sales receipt. Nutone told me after contacting them several times that they will not honor their warranty unless I...
Some People Hu...........Make sure that all filters are clean if need be renew..Sounds like overheating fault resulting in Thermal cut out operating....Good luck
Feb 19, 2011 | Broan-NuTone VX475 Bagged Central System...
Nutone central vac shuts down after a few minutes of use
this is a very common problem.
If the unit is less than 5 years old and you have your bill of sale it will be covered by warranty. Although one of my customers said that there is a recall on the motor in this unit. That is totally unverified. However, if it is still under warranty, contacting broan/nutone will give you the closest warranty depot, or they may just deal with you directly.
I do recommend that both the motor and the PC board inside be changed.
Good luck,
Mark
Nov 07, 2010 | Broan-NuTone VX475 Bagged Central System...
I have the Nutone 353 central vacuum. The last few times we have used it motor has shut down and then will come back up after an hour or so. Re-set switch does not seem to matter
I would try emptying it out and also cleaning any filters you have access to at the same time. It is usually a sensor for heat that stops the machine and if it is getting full or has plugged filters it will get hot fast cool down and then it will do it all again . Hope this helps you. Good luck
Oct 07, 2010 | Broan-NuTone CV350 Performance Bagged...
NuTone central vacuum won't shut off
http://www.centralvacuumstores.com/cvs/trouble_help.php#runs_continuously
Here is a link to help you find a local dealer:
http://dealer.nutone.com/DealerLocator.aspx?unit_id=002&cata_id=8
Dec 30, 2009 | Broan-NuTone CV353 Central Vacuum
Vx550 issues
Heven't fixed it yet, but I've pulled the motor to see what the specific issue is. As soon as I have the problem isolated and a solution, if possible, I'll post it here. I will have to contact Nutone Monday and see what they will do. If nothing, I'll sort it myself.
Tiny
Oct 02, 2009 | Broan-NuTone VX475 Bagged Central System...
My nutone cv556 wont shut off
It sounds like the relay is bad. This website has a pretty good trouble shooting page.
https://www.centralvacuumstores.com/cvs/trouble_help.php#wont_turn_on
Sep 28, 2008 | Broan-NuTone CV450 Central Bagged Central...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550c central vacuum
You ended chat so fast i guess that fixed ya ??
Aug 09, 2008 | Broan-NuTone VX475 Bagged Central System...
Nutone vx550 vac problem
The vacuum is defective, if you call Nutone and tell them the probelm, they will replace it for FREE, no charge to you. CALL 888-336-6151, that is the Nutone Tech Suport line.
Mar 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
