Question about Whirlpool Refrigerators
Whirlpool ED5VHGXM011 door ice flap won't close all the way and frost is building up
aasc
  • 1606 Answers
SOURCE: The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Posted on Nov 07, 2009
Sea Breeze
  • 4655 Answers
SOURCE: The flap on the freezer door for ice dispenser does not close
I will need that model number listed on the fresh food section behind the door and near floor kick plate, let me know if you have trouble finding the model number. Sometimes it is hard to find as every company puts theirs somewhere different, Thanks, Sea Breeze
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Posted on Jun 26, 2009
  • 112 Answers
SOURCE: shoot door (flap) for ice maker wont stay closed causing frost
the gear that pulls it closed is bad. some have small plungers instead of gears
Posted on Oct 29, 2009
richroth
  • 9472 Answers
SOURCE: fixing in door ice dispenser
What is the model number of the unit?
Posted on Nov 24, 2012
I have a whirlpool refrig model # ED5VHEVB06. The door where the ice comes out has a flap that does not close completely and a small black plug dropped onto the floor. Now the ice gets jammed and do
sorry , but to properly fix the problem you need to disassemble the door frame from the inside panel, if you are capable you may do but better to have trained technician to do it
Mar 18, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Shoot door (flap) for ice maker wont stay closed causing frost
Oct 28, 2009 | Refrigerators
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frost builds up in dispenser area .hard to open because of frost buildup.
The ice dispensor flap is not closing completely , causing the frost in the inside shoot and on the bottom of the dispensor . Sometimes caused by a broken ice guide ( clear piece attached to the arm that activates the dispensor on the door ) it hits against the flap , not letting it close . Model number would have helped more .
Aug 25, 2009 | Whirlpool Refrigerators
Ice maker works, fills door but doesn't come out
You have a bad dispensor flap solenoid . Frost due to flap not closing completely and ice will catch in the shoot .
Jul 25, 2009 | Whirlpool GS6SHAXLS Side by Side...
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Freezer keeps running
yes,you need to pull the front panel on the ice maker off to get to the solinoid that opens and closes the flap,with the flap vranked open you are letting cold air out and warm air in and that makes frost,if you don't want to try and fix it your self put a cloth towel in the chute to block the air lose and call an honest local appliance repair person-mike
Nov 15, 2008 | Whirlpool Refrigerators
Ice maker chute icing up
The flap is probably not closing properly. Dispense some ice, then open the freezer door and look to see if the flap is still slightly open. If so, you will have to take the front cover off of the control panel and clean the muck off of the flap mechanism and also clean the solenoid. I have to do this about 2X year. Not a big job, but be careful.
Nov 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
