Why does my LG Flatron W1952TQ Monitor TURN OFF?
Sometimes I have to unplug the monitor and plug it back in again and then reset the dpi and display back to 1440 x900
mjcarrasquil
SOURCE: I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Posted on Apr 27, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
SOURCE: LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Posted on Nov 02, 2009
Testimonial: "Excellent advise and many thanks. But it seems that this model does suffer some problems with this fault and LG knows it."
prashanthcl
  • 460 Answers
SOURCE: LG W1934S monitor. It displays an image for about
first you ensure that it is a problem with TFT or CPU. you can check it with another monitor. if it is working with another monitor then your TFT has been faulty.then you can repaired it from service center.
Posted on Nov 04, 2009
Testimonial: "Good direction for me to persue."
SOURCE: LG flatron L1970 h monitor flickers.
Just fixed mine :)
Biggest mistake was to try to open the monitor itself :( But I didn't brake anything :D
You just have to gently open the transformer unit (power brick) and replace two identical 1000uF 16V capacitors.
Here's how:
Remove the power cord first, to discharge the capacitors to avoid any nasty shocks when inside. Remove two rubber feet on the bottom side of the power brick. Just use your nail and lift them. Put them safely for later assembling. Unscrew two screws you just found under the removed feet. Now you have to unlock the other side held together by plastic locks. Try to apply pushing force and toque with screwdriver just where the seam is meeting the power cord socket's edge. Look for two identical capacitors and check if the tops are bulged of broken. I assume they are but you can try this method anyway. When the unit is disassembled you'll have to unsolder at least one of the wires that hold shielding plate on the bottom of the circuit board. Then unsolder the two capacitors (1000uF 16V). Replace them with the same type (1000uF) and the closest voltage possible. I have replaced mine with 1000uF 24V ones and so far I'm typing :D
That's it. If you have done this and looked for other damaged capacitors and replaced them also... Well then good luck disassembling the monitor unit and checking on inverter and lamps ;)
Cheers!
Posted on May 13, 2010
I connected a flatron w1952tq to my computer and I have video but no audio. How do I fix it
do you have speakers on your monitor? If yes, check the wire connecing hte sound to the speakers
Jun 11, 2014 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Does the LG Flatron W1952TQ Monitor have a reset button on it? Because it was working and now nothing. Monitor won't come on
The most common cause of power loss on the W1952TQ is a failure of the filter capacitors on the power supply board. This is the same board used in several of the LG monitors including the W2252. You can repair the monitor by replacing the capacitors on the board. Here is a link to a repair kit with the correct capacitors to rebuild the power board.
http://www.ccl-la.com/catalog/product_info.php?products_id=285
Apr 09, 2013 | Computers & Internet
How do i clean lg flatron W1952TQ screen?
According to the Owner's Manual (http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=W1952TQ-TF.AUSMAPN&matchedModelCode=1000004017&searchEngineModelCode=W1952TQ&initialTab=documents&targetPage=support-product-profile#), unplug it from its power source, then wipe it with a slightly damp (not wet) cloth; & don't spray the screen with an aerosol because the overspray could cause electrical shock. I suggest that with it unplugged from its power source, use monitor wipes (available at most office supply stores). Then plug it into its power source away from souces of water, & you're done.
Oct 12, 2010 | LG Computers & Internet
Lg flatron w1952tq goes into power saving mode on boot computer works fine on other monitor. Running Kubuntu linux.
your LG monitor is bad then if you put another monitor on the computer and your getting video. Just as a last resort, you might want to put the LG monitor on another computer and if it stays in sleep mode then you know for sure at that point, the monitor is bad.
Feb 06, 2010 | LG 22" FLATRON LCD Monitor
Analog power saving mode?...
I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
May 13, 2009 | LG 22" FLATRON LCD Monitor
Power saving mode knocks the computer out, have to restart
I have an LG Flatron 19" black w1952TQ that I bought on 2 Apr 2008; when it goes into sleep mode, will not recover. Did the online troubleshooting, reseting things, unplugging/replugging all cables, nothing works except restarting the computer, and that only works until it sleeps... Read more
Aug 05, 2008 | LG Computers & Internet
Screen is too
u do onething , remove the Monitor cover. adjust the screen preset ( LOT )
Jun 22, 2008 | LG Flatron L1951S 19" LCD Flat Panel...
LG Flatron w1952TQ (black)computer monitor way to BRIGHT!! How do I tone it down.
There are few buttons in the monitor select the menu button choose the Brightness and contrast change the setting of that and see which is comfortable and choose .same prob inform to fixya.com
May 13, 2008 | Computers & Internet
Bright screen with very low contrast
I fixed it myself, it seems that the monitor have some problems remembering it's settings and sometimes it automatically set its settings to crazy values that are out of the range that we are allowed to input. For my case, the setting that was crazy was the gamma setting since it was set so high. I wasn't able to bring it back to a normal setting so I found a way to do it by resetting the monitor. So to reset these display settings such as colour, contrast, brightness and gama, you need to turn on the monitor and unplug the monitor without turning it off and plug it back in again. It will automatically power on and the correct default settings will be present.
This forum isn't very helpful is it?
Dec 09, 2007 | LG Flatron L1811S 18.1" LCD Monitor
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
