I threw away the directions to my RCA universal remote and do not know how to access the first tv unit I programmed as it will only turn on the second one programmed!!!! Do I need the code and then wh
    Sergeant:
  • 319 Answers
Try going to this internet page. It has instructions for numerous RCA universal remotes. If you had included the model number of your remote you would have gotten more help.
http://www.ehow.com/search.html?s=RCA+Remote+Control+Manual&skin=tech&t=all&rs=1&channel=elec_tvs
Posted on Jan 04, 2013
  • 5 Answers
SOURCE: i need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Posted on Jan 14, 2009
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
SOURCE: RCA universal remote modle #RCR311w need instructions and codes for LXI tv
http://remotefinder.rca.com/default.aspx?site=rca is the only place you have to go to. It works!
Posted on Dec 23, 2008
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
Posted on Apr 14, 2009
What to use a rca universal remote but i dont know the code
3 Ways to Program an RCA Universal Remote - wikiHow
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowJump to Remotes Without "Code Search" Button - Using Brand Code Search ... (for example, many stereos don't support remotes). ... in this article to program the remote,but ... If you know the exact code that you need ...
Program an RCA Universal Remote Without a "Code Search"
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a "code ...Don't let go of the TV button. ... Please tell us everything you know about.
2 Easy Ways to Program an RCA Universal Remote Us
Dec 25, 2015 | RCA Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
How to program an rca tv remote to rca tv
Hello
Your RCA remote universal remote control model number is RCA RCU300T; I thinks and poste this solution to you.
Codes for RCA tv with this remote control are:
000, 003, 004, 005, 027, 045, 077, 089, 090, 094
In order for the 3 component universal remote to control
your TV, you must program it with the TV code that matches
your TV. These instructions explain the preferred method of
programming the remote-the Direct Entry method.
1* Manually turn on the TV.
2* Locate the enclosed TV Code List.
Find your brand of TV.
3* Press and release the TV key. The
indicator light blinks and then remains lit
4* Use the number keys to enter
the first code listed for your brand.
After you enter a valid three-digit
code, the indicator light turns off.
Note: If you enter an invalid code,
the LED will flash rapidly for 2
seconds. Start over at step 3.
5* Aim the remote at your TV and press
the ON•OFF key. If your TV turns
off, you have found the correct code
6* Enter the code in the box provided
on this page for future reference
7* If your TV doesn't turn off, repeat
steps 3-6 above, entering the next
code for your brand.
OK
Jul 05, 2011 | RCA 3-Device Universal Remote with...
I have a RCA universal remote & I mistakenly threw out the instructions. My TV is a ACER flat screen, how can I program my RCA remote?
Push code search Button indicator light go on.
Push TV button blink light on.
Enter codes??don't know my RCA books it old
don't haver ACER brand of tv.Might find it in the new RCA website.The best way it spend some money go to 1-800-Remotes Factory Original get the same rermote website.
Aug 12, 2009 | Televison & Video
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
RCA GuidePlus Gemstar Universal Remote Control 242524
i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
Jun 08, 2008 | RCA Universal Remote Control
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
How do i program my remote
Hold button down for unit you want to program. (TV,DVD,VCR) Then hold down on off button at same time. On/off button will turn off then come back on. When this happens push the play button. Wait 10 seconds and then push again. Repeat until unit turns off. Once unit turns off push rewind button one at a time until unit turns back on then push the stop button.
Sep 29, 2007 | RCA RCR311B Remote Control
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
