Need to network a wireless pc with a cable pc via router
The hard ware as follows.
1. Pc with wireless adapter
2. PC with onboard NIC cable
3. 4PortADSL Router.
what i want is a network environment for the 2 pcs to connect. the cable pc has a HSDPA Broadband internet connection. i want to share that with the wire less connection. i am no wiz at netowork. please give some guide lines.
  • chinthaka Jayasinghe
    chinthaka Jayasinghe Jan 27, 2009
    see, thats not the issue. i have a USB HSDPA MODEM. so i cannot hook that to the router
    chinthaka Jayasinghe Feb 02, 2009
    awsome. thanks works like a charm
    Problem Solver:
  • 13 Answers
Man u have a router!!!!!!!!!
no need to share the connection
just configure ur router,
put ur broadband connection log-in information in the router
so the router will act as a gateway
and the router will start the dhcp server, so both of ur pc's will have ip's from the same subnet
when the router connects to the internet
the 2 pc's will do the same,
Posted on Jan 24, 2009
  • ronraz2001 Feb 01, 2009
    first connect ur modem to ur 1st pc then connect a cable between the same pc and the router then connects the 2nd pc with router
    note : don't connects ur modem with router in (internet or wan) port
    lets say that ur modem ip/subnet is 192,168.0.1/255.255.255.0
    so ur pc that connects directly to ur modem will take ip like=192.168.0.30,
    go 2 ur 4 ports router and make sure that the router ip address is from the same subnet ex. ip=192.168.0.2/255.255.255.0
    and configure the router dhcp to use the following
    start ip address = 192.168.0.100
    end ip address = 192.168.0.200
    default gateway = 192.168.0.30 ( ur pc )
    dns = 192.168.0.30
    so the second pc will take from the same subnet,
    in this case if pc1 goes online the second will go
    but if the 1st offline the 2nd will be offline
    hope this was usefull
How to change the channel on my router?
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under wireless there is channel option8. the best channels to use are 6 and 11 then save it
Dec 28, 2011 | NetGear DGN1000 Wireless Router
Tip
Tips for Media state Media disconnected or Network cable Unplugged
Wired adapter or NIC Local Area connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a physical device or connections
Solutions: 1. Try with a different port on the switch or the router. It could be the fault with the Router/Switch port 2. Try a different Ethernet cable. It could be the fault with the Ethernet cable 3. Try with a different NIC or a different computer. It could be the fault with the NIC
Wireless adapter or NIC
Wireless network connection if says "Network cable unplugged" or if in the command prompt if you type "ipconfig" and if you come agross an error message "Media state media disconnected" then it means there is some problem with a some device issue or the wireless settings
Solutions:
1. Try scanning for wireless network and reconnect 2. Remove the profile or preferred networks from its list 3. Check and make sure the SSID and the Security KEY are correct 4. Restart the computer 5. Try with different security types like WEP,WPA or WPA26. Check if the MAC filter on Router/Access point is enabled
on Aug 21, 2010 | Computers & Internet
I m getting error on my dir-300 :network cable unplugged" and only power light is indicated. No other lights blinking. What to do? I tried to reset several time but not worth..
1. Make sure the LAN/ Ethernet cable and RJ-45 connectors at both ends of the cable are fine and the cable is not damaged.
2. To identify the problem, try a short cable and another PC/ Laptop
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Apr 04, 2011 | D-Link DIR-300 Wireless Router
Can i connect my xbox to my laptop /w pc usb
Xbox Network Connection using Hub
This is the most common network configuration and is also the easiest to setup.
Step #1: Plug your network cable(RJ-45 cable) that comes from your cable/DSL modem into the uplink port of your hub. (Make sure that your uplink is switched to "on").
Step #2: Take an RJ-45 cable and run it from one of the ports of the hub, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your hub directly to your xbox.
**NOTE** A switch may be used in place of a hub with the same basic setup.**
That's it! No other network changes should be needed for this configuration. Your Xbox is now on the same network as your PC.
Xbox Network Connection using Router
This is another common network configuration.
Step #1: Plug your network cable(RJ-45 cable) that comes from your modem into the WAN port of your router.
Step #2: Take an RJ-45 cable and run it from one of the ports of the router, directly to the Network Interface Card (NIC) installed in your computer.
Step #3: Take another RJ-45 cable and run it from a different port of your router directly to your xbox.
**NOTE** In steps #2 and #3, you should not use a port that is directly beside the "uplink" port on your router, if your uplink port is being used to connect to another routing device.** If your router has a built in firewall, you will need to forward ports 8602 both incoming and outgoing to the internal ip address of your pc. Consult your device manaul for port forwarding.
That's it! Your Xbox is now on the same network as your PC
Xbox Network Connection using Crossover Cable
This is the last network configuration. For this setup you need at least one NIC card.
Step #1: Plug your USB cable that comes from your modem into your PC's USB port. This should already be done, if you have a usb modem for your current internet connection.
Step #2: Take an RJ-45 cable and run it from an installed NIC card on your PC, directly to the Xbox.
**NOTE** A crossover cable is only needed if you are connecting the Xbox directly to the second NIC card. If you have a device such as a switch, hub or router in between you should use a standard RJ-45 cable. This type of network setup also requires "Winroute©", a program downloadable from the world wide web. Consult the manual for specific instructions on how to set this up. Also if you have a USB ethernet adapter, you may use any of the setups described herein. USB ethernet adapter basically converts a USB cable into an RJ-45 cable.
That's it! Your Xbox is now on the same network as your PC.
Aug 14, 2009 | Video Game Consoles & Games
Wireless router - establish wired connection with desktop PC
You are right, cable connection is more secure. The steps are:
1.) Connect the PC to the router with a crossover cable.
2.) Once connected, try to see if you are in the network. If you are, then you are ready to connect to the net.
May 04, 2009 | Computers & Internet
Teaming Intel Card
That NIC is end of life ...obsolete
Mar 02, 2017 | Computers & Internet
Need to find network driver
Solution:
i) Click on  Start button ---->Select option Control Panel------>Select Network Connections----->
   a new window appears showing the "internet connections icon " Such as:
   Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:   Local Area Connection 1 or 2 or 3
       Network Cable Unplugged, Firewalled
       VIA compatible Fast Ethernet
   in this case u can download VIA network drivers....from internet..
       or
  eg2:  Local Area Connection 1 or 2 or 3
          Realtek RTL8139 Family Fast Ethernet NIC
   in this u can download "Realtek RTL8139" network  drivers.... from internet(which is showing model    no: RTL8139 through google search engine )
                                                          (OR)
ii) Click Start button ---->Select RUN option ----> type in the text box    devmgmt.msc  --->Select Network Adapters....
but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the correct Model NO: of VIA or Realtek....
so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Dec 27, 2008 | E-Machines eMachines Refurbished EMA...
My computer (Dell) unknow Network Card
  or
        (OR)
    but this will show wheter ur network adapter or NIC is VIA or Realtek or......but doesnt show the           correct Model NO: of VIA or Realtek....
Thanking you
M.Sridhar
Dec 25, 2008 | Dell Ethernet Card Network Adapter
Set up 2 wireless routers, 1st for printer, 2nd for internet
You should only need one wireless router for everything. The purpose of the router is to "route" multiple devices together. Your set-up should be something like this:
Modem connected to wireless router via Ethernet cable.
Wireless router broadcasting wireless internet connection.
Computer(s) connected to wireless router via cable or wireless adapter.
Computer with network printer sharing enabled.
Turn on wireless printer.
You should be able to detect the printer via Windows.
Sep 05, 2008 | Office Equipment & Supplies
USB modem cable quandary
i am new too --may this trigger more people to help
from my limited experience
yes u need a NIC card in your pc
isp signal--->isp modem---->rj45 cable---->wireless (switch/access point/ Router--->NIC(PC)
---->wireless adapter (notebook)
----->wireless adapter(PC)
nowaday with a Gigabit Nic
u can match 802.11b 11mb/s
802.11g 54mb/s
802.11n 300mb/s
i use verizon at first with PPPoE
later Comcast cable dynamic
u need to go to web site ip address assigned by DHCPof your 3com wless router to make sure or/and clone the router so that it has same MAC addtress as your NIC of your PC before u can get CONNECTED with the Web----(u can see the green display on the upper right of the screen of the router page after u get connected) dl
Dec 25, 2007 | 3Com OfficeConnect Router
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
