On a Dodge Ram 1500 4x4 the tail lights stay on all the time. There is no indication on the dash that there is a problem. It is not a parking brake problem. Immediatly after use I turned off the truck and the lights stayed on. I disconnected the battery and reconnected it and they still stayed on. Help.....
I found on mine it was the brake switch under the dash.
Under the dashboard on the drivers side. look at the brake pedal lever. there should be a switch attached. push switch in and twist to remove. then pull the button as far out as it will go. while holding brake pedal down reinstall switch. then pull pedal up to top. this will reset the brake light switch. if they stay on still, then just replace the brake light switch.
I have the same problem with a Ram 2500 4x4. It is not the brake lights staying on. It is the tail lights. Also noticed the left turn signal works but the right turn signal stays on solid.
