Question about Hampton Bay 04314 Ceiling Fan
Hunter ceiling fan remote doesn't work
What direction does the fan go to cool the room...clockwise or counterclockwise? Also although the remote flashes a red light, it doesn't seem to change the light, speed or on and off. I checked the battery, but the red light on the remote wouldn't go on if there were no battery. I can't seem to change it with the chain either. Any suggestions?
  • 432 Answers
Counterclockwise for cooling. This blows air down. The electronics board maybe burned out. There is a small fuse and capacitor in the fan. You can buy parts for this fan. http://www.eceilingfans.com/
Posted on Jun 27, 2007
SOURCE:
Synchronize MinkaAire Remote Control Fans
use two remotes. one fan is in the reverse direction and other forward and it is easier to use 2 remotes.
Jun 02, 2018 | Dryers
How to reverse fan?
to change the fan from counterclockwise to clockwise get the fan going on hi. Hold the hi button while switching the wall switch from OFF to ON quickly. The fan will switch direction. To go from clockwise counterclockwise just hold down the low speed button until the fan switches direction. This makes no sense but it works only took 7 years to figure out.
Aug 10, 2014 | Hunter 27185 Remote Control
Should the bathroom fan light turn clockwise or counterclockwise
Which direction are the fan blade setup to exhaust the air out of the room? That is the direction it would spin, as this is not designed to pull air into the room.
Mar 17, 2013 | Broan-NuTone N-8663RP Combination Light...
Clockwise, counterclockwise which is the summer setting?
Ceiling Fan Direction These recommendations depend actually on the height and size of the room; the season; and the activity taking place in the room.
The basic fact of nature is that warm air rises to the top and cold air settles on the bottom. Air settles in layers from warm at the top to cold at the bottom, if left alone at equilibrium.
Ceiling fan recommendations:
In the winter
Set the fan to run counterclockwise (reverse; this looks clockwise as you are looking up). This will redirect the warm air from the ceiling and down the walls and into the living space where the people actually are. In a house, you would run the fan at a low speed so that you don't actually cool the warm air that you are moving downward. If you have a high ceiling, or are trying to heat a hall or a church, you may want to increase the fan speed so that the warm air will reach the living space as long as the fan speed does not create an unwanted downdraft at the people below. In the summer
In a room of normal height (8 - 10 ft), you should operate your fan so that it turns clockwise (this looks counterclockwise as you are looking up), causing a more directed downdraft, especially with the fan running slightly faster. This causes a wind-chill effect because the skin evaporates slight amounts of water from the sweat glands and thereby provides cooling through the skin's surface. However, the air is only moved but not cooled! You may find that you can turn your thermostat down a degree or two and save more money on energy costs. The air blowing down won't actually cool the room though, so you should turn the fan off when there are no people (or animals) in the room. In a high hall or church
It may be best NOT to run the fans at all in summer. This lowers the demand for cooling since the hot layer on top is an excellent insulation between the cool air near the floor (and the people) and the hot roof and outside.
A large, tall manufacturing hall would typically have different goals. There one would have a floor full of heat producing machinery plus the people operating it, working hard and welcoming a bit of a breeze. Then it would make sense to run the fans at fairly high speed to create a certain and directed downdraft. And with the shifts going throughout the days of the week, the fans should be running all the time and maybe in all seasons.
Finally, fans typically use 80-100 watts. When used properly, ceiling fans can really help to optimize the comfort level of the people and save energy and money.
Good Luck and please rate 4 thumbs up for the free answer
Jun 13, 2010 | Hampton Bay 13087 70450 Carousel II...
Installed the fan and remote will not reverse directions
switch on side of fan above the actual fan blades needs to be switched off . There is a directional fan swirtch that is located above the fan blades right in the middle of the motor housing should have to pull the sliding toggle switch oppsite of current position
Dave
Jul 16, 2009 | Hampton Bay 04078 Avanti Ceiling Fan
How do I make the fan reverse with RCR2 remote. Lost manual.
The fan should have a switch on it to set it for clockwise and counterclockwise direction. The remote usually does not control the direction.
Apr 21, 2009 | Ellington SBF58AN5LKRCR2 Surfboard Antique...
Fan direction
I winter it blows up to catch the warm air from the ceiling and bring it down. In summer it blows down to cool you off by evaporation.
Dec 24, 2008 | Hampton Bay 24750 Huntington III Ceiling...
How to replace a fluorescent starter
Although newer fluorescent fixtures have built-in starters or no starters at all, most older lights have an easy-to-change, visible starter. It is a small, silvery cylinder that plugs into one of the tube holders. 1) Shut off the switch. 2) Remove the tube. 3) Give the starter a quarter-turn in a clockwise direction, and pull it out. 4) Plug in new starter, giving it a quarter turn counterclockwise. 5) Replace tube. 6) Turn the switch on.
Jan 18, 2006 | StarTech.com CCTUBEGN 12.5''TUBE...
Hampton Bay 04314 Ceiling Fan Logo
243 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
