Question about AudioBahn A4004T Car Audio Amplifier
Amp wont come on
I have a 400 w 2 channel hollywood sound labs amp. I was hooking it up positive first and the screwdriver hit some metal on the amp and started smoking. The amp will not come on now. if anyone has a idea to fix it let me know. thanks
  • harperjay71 Jan 20, 2009
    I opened it up the board was burnt right behind the power terminal burnt where the copper foil flat peice. im not no whiz on this stuff my buddy was hooking it up and only had the power cord screwing it down but that amp has a metal cover band on the top of it he leant the screwdriver down and touched the metal band while he was screwing the power cord down. thanks for the help
  • Perry Babin May 11, 2010
    You will have to determine what smoked before you can attempt to repair it.
    Disconnect it from the power source (don't forget to pull the main power fuse feeding the amp) and open it up to see if you can see what smoked.
  • 113 Answers
You might have blown a mosfet transistor or resistor inside the amp
Posted on Jul 05, 2009
Subwoofer not working
burned out voice coils
also you could have blown your amp touch a 9 volt battery to the speaker connectors and see if the speaker moves or makes noise
if so the speaker may be okey
Jan 29, 2014 | Hollywood Sound Lab Car Audio & Video
How should i hook up a visonik class D vxd709 to my dual voice coil 12" Treo subwoofer?
if your amp is a monoblock 2 ohm stable amp wire the coils positive to positive and negative to negative into a single channel that will create a 2 ohm load turn your amp down and adjust by ear till it sounds good if your amp is a 2 channel amp 4 ohm per channel wire each coil one per channel turn amp down and adjust by ear till sounds good hope i was helpful
Feb 17, 2013 | Car Audio & Video
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
I have a 12 inch auduobahn 400 watt that is a special edition d jones. what is the best and most efficient way to install it with a jensen 400 watt 2 or4 channel mosfit power amp.
Is it a 2 or 4 channel amp???? Does it have a lpf (low pass filter)??? If its a four channel it prolly wont sound too great. If its a 2 channel you need to bridge sub to amp. Usually its the 2 outside terminals on the amp. Might have a diagram on the bottom of amp
Feb 27, 2012 | AudioBahn Car Audio & Video
How do i hook up the mrp-m1000 to 2 type r subs since it is a one channel amp? the subs r 4 ohms so it should work right?
hook the positive to positive and negative to negative on both subs then run wire to the amp the amp will see a 2ohm load
Jan 07, 2010 | Alpine MRP-M1000 Car Audio Amplifier
My 15 & 10
On a 10 inch subwoofer ranging between 80Hz and 120Hz, the box size required should be around 20 liters, meaning that you will end up with a box of 11 inches high, x 11 inches wide, x 11 inches deep. Or 275mm high, x 275mm wide, x 275mm deep. Seal the boxes with silicone for better bass
Oct 21, 2009 | Hollywood Sound Lab Hollywood Digital...
Hits hard with one sub but has no bass with 2
do you no what ohm your amp can do and what your subs are
Oct 07, 2009 | Lanzar VIBE286 Car Audio Amplifier
High wattage car stereo
positive (1 guage) from main battery to second battery positive terminal. hook all amps positive to second battery and hook 2nd battery ground to frame of car (where amp is now grounded) if you have a 2nd battery a cap is a waste of money. make sure all grounds (battery and amps) are together on same ground point of car, do not ground amps to battery - ground everything to 1 spot on the frame or body of the car ! - yes you can pigtail remote leads.
Jan 01, 2009 | Kicker KX650.4 Car Audio Amplifier
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Audiobahn A2300HCt wont work
you might not have enough power pushing the amp.... I have two batteries and two caps running
Apr 02, 2007 | AudioBahn A2300HCT Car Audio Amplifier
AudioBahn A4004T Car Audio Amplifier Logo
96 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
