Question about Canon imageCLASS MF5750 All-In-One Laser Printer
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed. Can anyone explain what the problem my be? Please assist me.
  • Anonymous Apr 13, 2009
    After getting a lable sheet jammed in the printer. I now have the Rec. Paper Jam alarm that will not clear and the paper wheels are clear and paper feeds with no issues.
  • Nancy Starr
    Nancy Starr Apr 23, 2009
    I have the same problem. Can find no evidence that there is paper in the printer, yet it still gives me this error message. Can someone help?
  • 3 Answers
Please assist me.
Posted on Mar 03, 2009
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Says paper jam but can't find any paper anywhere
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
False paper jam - printer takes the paper sheet in part way - then beeps and indicates a paper jam. If paper is assisted in - it works just fine.
sounds like the rollers have gone bad. there are rubber rollers that pull the paper down the paper path. if they are worn, it may grab the paper but will not have a good enough grip on it to send it all the way through. you can see there are replacement rollers for this unit, but usually reconditioning them with some fedron on a q-tip in a well ventilated area does the trick.
Jul 12, 2009 | Samsung SCX-4521F Laser Printer
Paper jam at exit
Here is a good help tool on eHelp.
I have a MF5750 and this was a great help.
http://www.ehow.com/how_113761_clear-printer-paper.html
I hope this helps you out, if not please respond to this post and I will try to help you further.
Jun 27, 2009 | Canon imageCLASS D680 Laser Printer
The paper jamed now I get a 41.3 error message and can't solve
The error 41.3 is unexpected paper length and was caused by the printer pulling more than one sheet. Now the problem is clearing the paper jam in the paper tray. The only way I have found to get it clear is to put the printer on its back with the paper tray facing straight up. Now push the tray in just a little bit if you can and try to shake it to get the paper to shift to the other end. After a minute or two put the printer back down and try to open the tray. If you can then just put the paper back where it goes in the tray. Be sure the pickup roller is clean, no paper dust and such. then try printing again. If you still can't get the tray out then you will have to dis-assembly the printer to get it clearer. Let me know if this gets you going.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 19, 2009 | HP LaserJet 4 plus Printer
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Jarry cannon
open printer cover, pull out toner cartridge, re-install cartridge, close door, it should re-boot the machine.
Mar 14, 2008 | Canon LaserBase MF5750 All-In-One Printer
Paper light
Look in the back of the printer and we found a jamed page.
Sep 12, 2007 | Brother HL-2040 Laser Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
295 people viewed this question
old marine
old marine
