Question about Water Heaters
My water heater codes out on c713,miss placed my manual,what is that code
Best water heater i ever had,owned about 6 yrs with not a single problem,started tripping out with a c713 code
3 Suggested Answers
  • 244 Answers
SOURCE: Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
Posted on Nov 01, 2009
SOURCE: The water heater cuts off
I am a free answerer, and I specialize in giving you resources for free
The paid answerers may have a person who knows your product and the error codes
The manual will also have the error codes.
The person who installed the unit will also know the error codes (or should know)
Each day I see 20-25 unanswered questions about tankless water heaters.
The number of questions shows the complexity of the machines, and the inability of the manufactures to take care of their customers.
The manufacturer will refer you to the installer.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
http://www.rheem.com/products/tankless_water_heaters/
The link above goes to Rheem tankless water heaters
Click on a product and it opens a page showing many tankless models
Click 'more information' and another page opens with spec sheets and other pdf
Not surprisingly there are no troubleshooting steps or troubleshooting flowcharts
There are plenty of ways to buy a tankless
There are not many ways a do-it-yourselfer can fix a tankless
Posted on Oct 30, 2010
I have 6 single flushing code
Copy following link to identify gas control and download error codes and troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
h
Nov 14, 2013 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I have a Richmond tankless water heater and it has L1 error code...can somebody help me with this?
Might be able to help. Except L1 does not show on any error code file.
Copy following link for Rheem Richmond Ecosense etc computer water heater troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Are you sure the error is not IL? Delime tankless.
Or UL flashes and indicates reset.
Or CL flashes and indicates fault history is cleared.
Or error 11 combustion failure? Call for service.
Or P1? Low water pressure, clean water filter check for leaks and crossover caused by bad single-handled faucet cartridge.
I recommend calling Rheem to find local technician who is qualified to work on tankless computers. Tankless are not ordinary water heaters, and they require continual maintenance to avoid common error codes, especially as unit gets 2-3 years old, after warranty has expired.
The required maintenance and expense of repairs, and general fact that people cannot make their own repairs, make tankless computers a bad choice for heating water.
If unit is 4-5 years old, it might be best to install tank-type heater for $385 from Lowes and cut losses.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 08, 2013 | Rheem Richmond Encore Tankless Nat Gas...
Error code 71
Absolute best solution for Tankless water heater is to replace whole thing with tank-type water heater and quit spending money fixing an old computer with multiple sensors that is connected to your water pipes, electric line, and gas line, that is connected to a gas burner with vent pipe to outdoors ... As if each of these systems doesn't have a load of problems on its own without a computer chip.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
Otherwise, I do not have a source of information that is better than a service manual.
Apr 24, 2013 | Rinnai R75LSi Interior 7.5 GPM Natural Gas...
I have a new Richmond tankless. Every time someone turns on the water for a second the water heater comes on for a second. Is this ******* the unit ? I tell people to just use the cold water tap if th
Before calling service technician, copy following link for troubleshoot resources:
If tankless comes on when HOT tap is turned on, then that is normal.
If tankless comes on when cold is turned on, then you might have crossover:
http://waterheatertimer.org/Crossover.html
If tankless comes on when single handled faucet is lifted in center, then that draws water from hot pipe and will activate tankless > so don't install single handled faucets to save water heater energy, regardless what type water heater you have.
Tankless require monthy-to-yearly maintenance to avoid common error codes. The product manual recommends yearly service. Since Rheem does not post service manuals, you generally have to pay somebody to take apart and test the unit. The cost of this far outstrips expected savings from owning expensive water heater that requires lots of maintenance, yet is heavily promoted as the solution to water heater problems.
Never install tankless water heater is best way to avoid complications of expensive water heater that is maintenance heavy, hard to diagnose, expensive to fix, etc.
Never expose tankless to more than 11 grains hard water.
http://waterheatertimer.org/pdf/Rheem-CondensingTankless-maintenance-2012.pdf
Aug 25, 2012 | Rheem Richmond Encore Condensing Tankless...
My water heater error code 1 model ee3250rd055v what does this mean
Water heater is not 100% identified.
Unknown if this is gas or electric heater.
Problem posted under Whirlpool water heaters typically made by American water heater company.
Call Whirlpool 877-817-6750.
They will ask for model number and serial number located on label on side of tank.
Call is answered in USA by trained person who can answer specifics about that model, including warranty, age, regular maintenance, error codes, and possible solution for that specific model and serial number.
I have found these folks to be helpful.
Whirlpool manuals do not show that specific model:
http://www.whirlpoolwaterheaters.com/support/manuals.aspx
If you have the energy smart electric water heater with electronic control board, then error code explanation shows on the control board. Error 1 or a single flash, is start-up failure and requires tank to be full of water. Read page 10 of manual. Make sure water heater is full of water and water is coming full stream out of tub spout before turning on power. Also disconnect power from unit, make sure water heater is full, and then reconnect power to see if unit resets.
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
http://www.whirlpoolwaterheaters.com/downloads/6510306.pdf
Sep 12, 2011 | Whirlpool Water Heaters
I have a richmond power vent water heater model number 6G40POW-40F.It will run for 2 min then shut itself off then restart and do the same thing all over.Then 2 lights come on and it wont run. Any help...
Fastest way to solve water heater problem is call plumber or service technician.
Open following link for typical error codes for intellivent gas valve found on newer Richmond/Rhemm power-vent gas water heaters:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
There is no 100% sure way for novice to repair gas water heater.
This is because electrical parts have to ohm-tested using information from service manual that is typically not sent with new water heater.
Also parts have to be cleaned. The gas pressure checked, air in gas line removed, burner tubes and pilot tube and combustion chamber cleaned, burner parts inspected for problems, air intake cleaned, exhaust vent tested.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Best way for do-it-yourselfer to solve water heater problems is to learn as much as possible about specific model by reading product manual that comes with new heater.
The manual will show error codes.
Then keep up with yearly service recommendations shown in manual.
Aug 03, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
The pilot light goes out on an intermittent basis - one week, two weeks or more.
Before calling service technician, open following link for Rheem troubleshooting resources.
No error code: Without an error code, there are innumerable internal and external factors ranging from a simple plumbing crossover, to bad PC board.
Open link above and read no-error-code, and find copy of manual if available.
Best place to start is manual.
Read troubleshoot section, advisories, and required maintenance.
Burners require yearly cleaning, heat exchangers require yearly de-liming, and water filter should be cleaned monthly. Tankless are complicated machines requiring research, experience and expertise to diagnose and make successful repairs.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 23, 2011 | Rheem Water Heaters
The water heater cuts off every night while taking bath. The water turns cold and up to the attic we go to reset. A code of C713 is flashing.It also is flashing the code 1L after resetting. This is a Rheem...
Oct 30, 2010 | Rheem Tankless Hot Water Heater...
Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Oct 04, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
42 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
