Question about Inverter Siemens Micromaster 440
Have alarm F453 on micromaster 440 drive - Inverter Siemens Micromaster 440
3 Suggested Answers
  • 3 Answers
SOURCE: When I power up the micromaster 440 i get a screen
may be the BOP is not correctly connected
or the supply provided for 2phase has to be interchanged
Posted on Feb 23, 2010
SOURCE: micromaster 440 6SE6440-2UD42-0GA1 faults alarm
what a fault 001
Posted on Aug 23, 2011
How do I clear error code F0022 on Siemens vfd
F0022 - Hardware Monitoring Active (as Im sure you are aware)
This cannot be 'cleared' without a repair.
Likely several components internally need to be replaced.... if you can get them.
There are too many possibilities to list here and recommend you dont spend your time trying to repair it yourself. It may well be in vein!
Consider sending it for repair or service exchange.
Jul 22, 2014 | Inverter Siemens Micromaster 440
Micromaster 440, a few seconds after i power up, F0022 appears
This is most likely a fault with the IGBT even if it meters out correctly.
They can be replaced but the cause cause of the fault in the first place may still be present and might damage it again.
Occasionally there are further issues from faults like this so I would give some thought to doing a service exchange with a repair company.
Jan 21, 2014 | Inverter Siemens Micromaster 440
Micromaster 440 alaram F0022
Likely to be IGBT fault. Unless its a large drive I would service exchange it or bin it. Not worth the hassle.
May 14, 2012 | Inverter Siemens Micromaster 440
Sometimes I have problem with high rate of voltage DC link
A bit late but it might be of use to someone.....
Siemens have published a pdf document about this Item-ID: 22445905
I found it here - http://support.automation.siemens.com - but their search facility is a little hit and miss!
A quick google usually brings it up top of the results.
Apr 10, 2012 | Inverter Siemens Micromaster 440
My name is rall i have a siemens micromaster ac drive .37kw single phase and it working with one siemens plc s7 ,plc send analoge signal (4-20ma) to it for running but it dosent run. but in local mode its...
jst chk out the connection of the plc and find that the resistence of 500 ohms linked with 10v which converts 10v to 4-20ma is working if it is then it will work or check the drive's connection n parameters of P1300 & communication parameters
Dec 13, 2009 | Inverter Siemens Micromaster 440
When I power up the micromaster 440 i get a screen that shows -----, What does this mean?
Oct 20, 2009 | Inverter Siemens Micromaster 440
I have a 15kw motor driven off a siemens micromaster 440. I cannot get the motor to run in delta. I have to run it in star. I have similar drives on site and these motors are connected in delta. what...
Why do you want to run the motor in the delta configuration? The VFD will change the speed to anything you want to do. The delta and Wye connections are normally used to change the speed of a motor. That's what the VFD is for...??
Sep 28, 2009 | Inverter Siemens Micromaster 440
Inverter Siemens Micromaster 440 Logo
741 people viewed this question
Top Inverter Electronics - Others Experts
ray gallant
Tom Chichester
George Scott
George Scott
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
