Question about Sharp R-1874 Convection/Microwave Oven
Fuse blowing on the sharp microwave r-1874
I have had the tech out twice, once he replaced the fuse and once the stirrer motor. It's blown again and they say it has to go into the shop to be taken apart.
what do you think? For today I have a fuse and would like to replace it! I've taken apart the panel and don't see where the fuse belongs? I'm looking for a picture online..
Thanks for your help.
  • 686 Answers
Your fuse will be located somewhere close to where the power cord comes in. It's not a regular glass fuse it looks like ceramic with the silver looking ends that's your fuse
Posted on Feb 20, 2009
Sharp sound bar buzzing
test this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Read more:
Oct 12, 2013 | Microwave Ovens
The internal 8a ceramic fuse has blown on my Sharp platinum collection 900w microwave oven, model R-957. fuse is marked F8AH 240V and is located on a small circuit board inside the rear of the oven. is...
Don't know if this a regular problem with this unit, but for this fuse to blow, there must be a problem further downstream. Maybe with the power supply or the Magnatron.
Sep 07, 2010 | Sharp R-1874 Convection/Microwave Oven
Not heating
Remove the outer cover (pull the power plug first) and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan-like device located within the sheet metal wave-guide near the opening in the cooking cavity where the microwaves come into it). This stirrer has a plastic bearing that frequently arcs over and permanently shorts out the microwaves which blows the fuse. If no blown fuse is found, look for a loose or defective door-interlock micro-switch.
Nov 17, 2009 | Kenmore 61652 Microwave Oven
My Sharp R-1874 over the range oven quit working. Is there a fuse?
Yes. Unfortunatly, the fuse is usaully located behind the keypad mounted on a circuit board. You may have to remove a few screws to remove it. hope this helps.
Sep 26, 2009 | Sharp R-1874 Convection/Microwave Oven
R-1874 shuts down after 59 seconds
That switch is supposed to tell the computer if the damper door is open or closed. If it does not go to zero ohms, the CPU doesn't know what to do. Check the thermistor too...... just in case...
Sep 12, 2009 | Sharp R-1874 Convection/Microwave Oven
Over the stove microwave just stopped working. Circuit breaker was not tripped.
Sounds like the fuse is blown, you will have take the outer case off to find the fuse and replace it
Sep 07, 2009 | Microwave Ovens
[Identical to earlier posting by stefeckstein]
Check for a circuit breaker on the back. If nothing, pull the plug and remove the case. Look for a blown fuse. If so, look for a shorted high voltage diode in the magnetron power supply or a shorted stirrer bearing located above or beside the cavity area where the microwaves enter. The stirrer is a metal fan-like device with a plastic bearing that often arcs internally. That shorts the microwaves out and blows a fuse. Replace the stirrer.
Aug 24, 2009 | Panasonic NN-SN657SMicrowave Oven
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Shuts down after 59 sec
Chances are you have a bad damper switch or wiring. A sample photo is here: It might also be a problem with the humidity sensor or a problem with the control panel, such as corrupted code or bad connections.
Dec 20, 2006 | Sharp R-1850A Convection/Microwave Oven
Sharp R-1874 Convection/Microwave Oven Logo
786 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
