Question about Panasonic KX-TG6021 Cordless Phone
Display on cordless digital phone has vertical lines with L1 L2 and VE across the top
One handset displays black vertical lines with L1, L2, and VE on top of the black lines
cnavarro
  • 2460 Answers
SOURCE: I have a Panasonic cordless
Start by swapping the batteries between units. If the formerly bad handset charges, it's a battery. If not, look for dirty contacts where the unit sets into the base or the batteries fit into the holder.
Carl
Posted on Sep 01, 2008
  • 3 Answers
SOURCE: Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Posted on Aug 13, 2008
cnavarro
  • 2460 Answers
SOURCE: line not assigned
Somewhere, floating around, is a TDA Users manual. Program 19 and 20 deal with Idle line preference out and in. You could have a couple of things going on, one is that you lost your ILP, or the line assigned to it is no longer there. If it's the former, try this:
PROG 19 0 is no line 1 is Idle CO 2 + a button is that line, and 3 is intercom. Press STORE after the sequence and try it.
Worst case is you do 19 3 and get it to the intercom on idle.
For incoming PROG 20 0 is none, 1 is longest ringing, and 2 plus a line is to prefer that line, used when you have a private or semi-private line that you need to answer. Again, press STORE to save your selection.
HTH
Carl
PROG 19 0 is none 1 is
SOURCE: handset constantly display missed calls
you have to clear them. it will show missed call on all the ones you did not answer the call on.
Posted on Mar 09, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
Why are vertical lines across the display screen of my handset? Have changed the batteries.
The handset display is bad. This part can not be replaced because it is molded to the chassis of the phone. Replace the complete chassis or the handset and that would solve your problem.
Feb 26, 2015 | Panasonic KX-TG6021 Cordless Phone
Surface work but display and oven do not
Bigejpp, start with the basics, On the back of the range where the cord hooks up see if you have the correct power. Three terminals, you should have 120V from each end to center and 240V across the two outer terminals on the terminal block. If you don't have this, the problem is in the breaker. If you do have it, remove the upper back panel and look at the board. You will see L1 L2 and L2 out which goes to the elements. Test for voltage at L1, should have 120V. If you have power to the board and no display, the control is at fault. This is for a 790.95320 electric range. If your model does not beging with 790, most electric ranges operate in a similar matter. Catriver.
Jun 14, 2007 | Kenmore 95320 / 95321 / 95322 / 95324 /...
TCL 14175 Vertical adjust
Hello
You have to enter its serive mode options to adjust picture height. Whithout its origianal remote handset, it is impossible.
Mar 07, 2012 | Televison & Video
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
HOW DO I TURN OFF THE ANSWERING MACHINE FOR THE RCA VISYS MODEL 5RE1A..?????
Briefly press the Answer L1 or L2 button, it displays the answering status on LCD. For example, L1: ANSWER OFF.
To change the status, press and hold the Answer L1. Unit will display and announce the new status of the answering system.
Nov 02, 2010 | RCA ViSYS 2-Line Speakerphone
AT&T Model 854 4 line phone, turn off unused line lights
It's a matter of cabling.
Make sure that only the line you wish to use is connected.
If all of the lines are cabled with two to four line cable, then reduce the cabling to a single red/black combination on the one line.
Apr 25, 2009 | AT&T ATT-974 Corded Phone
L1, 2 and L3 versus COMM
what kind of light switch are you replacing??? assuming house light switch???
one way or two way switch??
I have not come across the type of switch before.
L1, L2 is just label as line 1 and line 2, comm is usually refer to common (ground wire-white).
is the red wire-hot???
Oct 23, 2008 | Electrical Supplies
Defaults to Line 2
Do you have a second phone? Be sure that phone is not defaulting to line 1. With 2 lines and 2 phones, each phone defaults to one of the lines.
Unplug the phones. Plug in the phone you want to default to line 1 using the L1+L2 jack. Now plug in the second phone.
May 22, 2008 | RCA 25205RE1 Phone
Maytag slide in range - MES5752BAW - when you press BAKE or BROIL the power cycles off and the number 30 flashes on the display then the power cycles back on and the clock is reset to 12:01.
I had similar issue with my Maytag slide in range MES5552BAB. Pressing Bake or Broil would sporatically cause clock display to go blank, show "30" then reset clock to 12:00. Under warranty, the service technicians replaced the clock unit twice. On last visit the range performed the error while technician present.
The suspected problem is that the clock unit is experiencing high frequency interference.
The proposed solution is to place noise suppressors on L1, L2 and Ground wires at the clock. (Noise suppressor: Ferrite beads, Sears Part #12001500.) Reverse L1 and L2 at the pigtail terminal block.
May 06, 2008 | Kitchen Ranges
Static electricity
I had the same problem when I answered my cordless phone static charge went thru me and into my phone and I had now display, so i changed the batteries in the handset and it worked. So I hope this works for you.
Feb 29, 2008 | Uniden DCT646-2 Cordless Phone
Panasonic KX-TG6021 Cordless Phone Logo
89 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
