Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Outdoor keypad frequently doesnt work
Punch in codes on outside keyless pad, wont open unless i try it many many times. Seems worse in colder weather. Checked battery and it is fine. This is a Liftmaster unit. Has two doors with separate codes. Same issue for both.
  • kris3186 Jan 20, 2009
    Problem started about four days ago. At first, the numbers on they keypad would still light up, but the garage door wouldn't open. Then there was nothing. I replaced the battery and still nothing. Any suggestions?
  • 504 Answers
IF REPLACING THE BATTERY DOESN'T DO IT YOU WILL NEED TO REPLACE THE KEYPAD.
NOTE: (IF YOU HAVE A ROLLING CODE SYSTEM) YOU WILL NEED TO REPROGRAM THE UNIT AFTER YOU CHANGE THE BATTERY.
HOPE THIS IS HELPFULL
Posted on May 23, 2010
Keyless pad will not communicate with reseiver
Are you sure you purchased the right keypad? The model you should have is 139.53681
May 03, 2012 | Sears Craftsman LiftMaster Chamberlain...
Tried to reprogram security code for outdoor key pad on 1/2hp craftsman garage door opener according to instructions online, pressed learn button- put in new 4 digit code-held enter. Lights did not flash...
Seems you've done everything right. Press and immediately release the smart/learn button and then walk over and key in a 4 digit code and press enter. If you are sure the battery in the keypad is good then I think your keypad is on the fritz or the wrong one for that opener.
Apr 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
Just bought a new PD210DM opener but still have
I don't know this model. (in australia). the chamberlains here are probably the same. the 4 digit code you first put in the keypad is what you have to use. push the learn button on your operator then punch in your 4 digit No. Hold the enter button on your keypad until the light flashes on the operator.
That should code it in.
freddy51
Feb 08, 2010 | Sears Craftsman LiftMaster Chamberlain...
ALL OF A SUDDENT HE OUTDOOR KEYPAD NOT WORKING.
It could be the cold but it most likely is your keypad just failed.
Dec 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
How can I reprogram my keyless pad?
If you mean wireless keypad it is like this. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Oct 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman outside keypad
On the back panel of the opener itself is a small pushbutton. Press the button and the indicator near it will light. While the indicator is lit, enter the new 4-digit code on your keypad and it will be set. (You are actually programming the receiver with the new code this way. The wireless keypad doesn't store a code.) The programming light goes off on its own.
Feb 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't get Domino keyless entry pad to work
Call Domino. Sounds like button on pad worn out. Confirm by trying new code with ALL FOUR numbers different. If it works, you can just change you code. If you have patience, find the bad button , ie: If code were 6529, try 6666 and see if it works. If not, 6 is 6. If yes, try 5555. You get the idea.
Jan 14, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Outside garage door key pad will not function in very cold weathe
Yes, that is an issue.  My suggestion is to replace the outside keyless with a wired keyless (Domino GD-1).  This will get your batteries inside so they can stay warm.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
229 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
