Question about Honeywell Programmable Thermostat Heater
Honeywell rth2310b battery replaced now no heat will go on
The batteries died...after replacing batteries i programmed it but the heat wont go back on and it still says there is low battery... what do i do?
5 Suggested Answers
SOURCE: Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Posted on Dec 30, 2008
SOURCE: flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Posted on Feb 18, 2009
FixinFax
  • 3085 Answers
SOURCE: I lost my RTH2310B manual
http://customer.honeywell.com/techlit/pdf/69-0000s/69-2229ES.pdf
Posted on Nov 07, 2009
SOURCE: The battery in our Honeywell ST6400C programmer
Hi shastalaker
Thanks for the info but how to get the front cover off. Two screws underneath allow the whole unit to be removed but then - nothing. There are two plastic tabs but they do not release anything as they are at one end. The other end remains firmly fixed.
Any thoughts
BigAl
Posted on Feb 19, 2010
My batteries died on mt heat control, I changed them and now have nothing
http://www.gogeisel.com/geiselonline/support/Honeywell/CT3300_CT3355.pdf this is the programming manual- they have a note that if you show low battery after replacing the battery- put the battery in backwards, wait 10 seconds, then put the battery in correctly again to reset it- you will have to reprogram the clock time and date and any settings you had previously.
Mar 02, 2015 | Honeywell Electronic Programmable...
Battery saver comes on battery light wont start like low battery started 5 min before code p062f comes up
Since you give no make , model or year of vehicle, I will assume it is fairly new if it has a battery saver feature. New cars are programmed to shut down non essential components to conserve power to start a vehicle that has marginal voltage to start the engine. Seems your battery is dying and your car is warning you that it may not start if the problem is not attended to ... Have your electrical starting system checked. Battery alternator, and load check.. Replace battery or alternator if needed.
Feb 12, 2015 | Cars & Trucks
Change battery work for a hour all so die and wont start backup again
I would take the battery back and exchange it or have them bench test it.
Terry
Mar 08, 2014 | Samsung Galaxy Tab 2 7.0
1994 Toyota tercel dies while driving,starts when crank couple time.will run good on freeways,only dies when driving in short steets.some days wont die.new timimng belt,reman distributor,cap,rotor wires...
have your alternator checked it sounds like its putting out low voltage you can do it you have a volt meter just hook it to the battery terminals you will be looking for a range of 13.5 volts to about 14 volts if your under thirteen its not enough voltage for the car to run and charge the battery at the same time.
Oct 09, 2013 | 1994 Toyota Tercel
My iphone died from low battery and will take charge but not turn
sounds like you need a new battery, this is a tough one to fix... i would search craigslist for people that will fix it they are everywhere.
May 05, 2010 | Apple iPhone Smartphone
My heater will not work
the remote is the "brains to the heat pump/air con, low battery power or spent batteries will effect the cycle between indoor unit and outdoor unit, replace the batteries and turn off curcuit breaker at main switch board for a couple of minutes and turn back on. Try restarting unit.
Jun 05, 2009 | Heating & Cooling
Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
May 02, 2009 | Honda Accord Cars & Trucks
Dies after running
When it won't start does it have spark? (Ignition module)
Apr 08, 2009 | 1989 Pontiac Firebird
Digital camera samsung 301
The camera has died Get onto Samsung Tehnical Support for their solution
Jul 14, 2007 | Samsung Digimax 301 Digital Camera
Heating & Cooling Logo
363 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
