Question about Singer 7462 Mechanical Sewing Machine
Lights flashing and beeping.
Every time I push the foot petal, the machine beeps and all the lights flash. There's nothing stuck inside, and the machine is clean. What's wrong?
  • davs Feb 07, 2008
    I took my machine with me on an airplane and now when i try to sew wit it it makes one stitch and then all the lights start flashing and it stops. I have made sure that my threads match and that everything is threaded right, as well as the BH Button being up. It is driving me nuts because I can sew with it by turning the handle, but it wont itself past one stitch.
I had a similar problem and called 1 800 4Singer. The BH lever(next to the needle) had fallen. I pushed it up and everything worked fine again. It seems if it's down the least, the machine won't work. Hope this helps.
Posted on Aug 25, 2007
Trying to thread bobbin and viewed manual several times. singer model 7258. screen first flashes C3 and then ][. cannot find troublr shooting codes in manual.
Why do I keep getting a C3 error (accompanied by lots of beeps) when I turn on my machine?The C3 error as well as the beeping when you turn on your machine indicates the foot control plug is not fully pushed into the sewing machine. Turn off your sewing machine and push the foot contol plug into the machine fully. Turn your sewing machine back on.
Oct 22, 2017 | Singer Sewing Machines
Janome dks 100 se - it keeps beeping when I press the foot pedal and I have to do this several times before it starts sewing. It doesn't beep when using the stop/start button and is sewing fine
Same machine and model and same problem. It’s really irritating. It’s not the bobbin as the screen flashes worth the foot pedal. I’ll look at the tension but given how often it beeps and on so many different projects with different thread and tension it seems to be a fault of some kind... searching for a fix...
Sep 13, 2017 | Janome Sewing Machines
Hi! I have a janome dsk30 that keeps beeping with the foot control light flashing. The only way to clear it seems to be to unplug the control foot and plug in again -any ideas?
Sounds like it is getting too hot if it is OK after unplugging. Is something stuck in your foot pedal? Give it a clean and hoover as dust and threads can get stuck there. Good luck
Apr 29, 2015 | Janome Sewing Machines
Stitch selection control panel lights flash and beeping
is the bobbin lever back in it's original position? it could be a problem with the computer, here is a link for a free manual, just in case you don't have one
http://www.singerco.com/uploads/download/466_7462_efs.pdf
Apr 17, 2014 | Singer 7462 Sewing Machine
Singer confidence 7463 all lights flashing
try
rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
try changing the needle
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
My Rose sewing machine will not sew. It beeps and the presser foot icon flashes. I have re threaded, re bobbined, re placed the presser foot, and I think I have cleared the memory, but I am not really...
That light means you need to lower the presser foot. It cannot sew until the foot is lowered. The lever to lower the foot is behind the needle area on the back.
Feb 05, 2011 | Husqvarna Rose
7436 beeps problem
Raise your button hole lever which is near the presser foot.
sewman7
Jun 11, 2008 | Singer 7436 - INGENUITY
The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Oct 27, 2006 | Singer CE-100 Futura Computerized Sewing...
Singer 7462 Mechanical Sewing Machine Logo
567 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
