Question about Saws
I brought home my Craftsman 10 Inch band saw, Model #124.21400, assembled it, however the blade keeps moving to the left and does not saw straight. Suggestions anyone?
Tried tightening the blade.
the recycler
  • 22 Answers
SOURCE: Porta Band saw blade jumps off
I had this problem on a used model 725 that I bought. Apparently the rubber tires on the drive wheels develop a bit of a memory after sitting for a while with tension on the blade. I tried cleaning the tires to no avail. Then I removed both tires, flipped them over and re-installed. Still not fixed. Then I put only one back to the original position and the problem was solved. Other than the frustration of trying several times, I was out nothing and I got quite proficient at taking the blade in and out. The saw has worked fine ever since. I hope this simple (and free) solution works for you.
Posted on Jan 12, 2009
  • 2692 Answers
SOURCE: Band Saw Blade won't stay on
A lot of the larger band saws, and I don't know about your particular model, has an ajustment on the bottom wheel that tilts the wheel in order to track the blade. It is right at the axle and tilts it from there.  If the back guide is a roller bearing I woud think you would want to roll all of the time.  If a solid bearing block natually a small space where it  will not hit is enough.
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: straight cutting with rip fence
when i use my table saw, i use clamps on the fence, i dont rely on the one built in.
Posted on Feb 26, 2009
  • 5 Answers
SOURCE: NEED BAND SAW BLADES FOR MY OLD BLACK & DECKER
sometime you can get lucky on ebay. thats one place you check. the best thing about it that it's nation wide. i found alot of odd items in there.
Posted on Jun 24, 2009
  • 67 Answers
SOURCE: Band saw blade wanders.
cut freehand. A bandsaw blade will always run off to one side or the other, even using a fence.
The rip fence is intended for re-sawing only, and very thin strips
Posted on Jul 24, 2009
Get a 12 "Sears craftsman band saw blade model no 113.279521c
I'm using Haltbar band saw blades that I got from sawblade.com . They have great quality band saw blades. I ordered 10 blades from them last month and shipping was free.
Oct 18, 2014 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
How to replace blade on craftsman 10 inch ban
Here's a good blog about changing band saw blade. Or you may also want to watch instructional videos. How to Properly Install Band Saw Blade
Aug 28, 2014 | Saws
How long is the saw blade on a 12inch band saw
The manual says that it will support blade widths from 1/8 inch to 1/2 inch. You can use 80" or 80 1/2" band saw blade. I got my band saw blade on sawblade.com . I like them .
Jun 06, 2014 | Craftsman 12 Inch Band Sawsander I2 X80...
The guide assembly on my 14" band saw will not stay peralell with the blade as it goes from the top of its travel to the bottom. it goes right to left going up and reverse going down the blade . the o
Sounds like something's bent. You might need some replacement parts. 14" band saws, regardless of brand, are generally made with Chinese parts that are knockoff Delta-Rockwell parts from many years ago. Grizzly sells most of these parts at reasonable prices. Check the exploded views of their saws to see if the parts match. Craftsman parts are expensive, even though they're the same part.
Mar 30, 2014 | Carter Products Rikon 14" Sears 14"...
Setting the proper tension on a Craftsman 10" band saw model 124.214000.
Hope this blog will help you http://bandsawblog.com/blade-tension/ .
What's your band saw blade? I am using Haltbar blades and never got problems tensioning.
Feb 11, 2013 | Craftsman Saws
10 inch table saw blade not square with table
Sounds like the bolts that hold the motor assembly on the table may be loose allowing the blade assembly to move. Look underneath the table and clean out all the dirt and loosen all the hold down bolts and realign the blade and tighten back up.
Oct 25, 2011 | Craftsman 10" Table Saw
I cannot easily raise/lower my blade on my Craftsman 10 inch table. I've cleaned out the say thouroughly and nothing appears to be obstructing mechanism to raise/lower the blade, but yet, it takes two...
mine did the same and i sprayed WD-40 on the assemblys or large screws and keep working it until free. but, check things over because some had a lock so the blade wont move after the hieght is set.
Dec 19, 2010 | Craftsman 10" Table Saw
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Dec 08, 2009 | Craftsman Saws
Straight cutting with rip fence
Feb 26, 2009 | Craftsman 1/4 x 72-5/8" Band Saw Blade, 6...
Saws Logo
145 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
