Question about Bosch Tools & Hardware - Others
Bosch pho 20-82 planer
How do i replace the brushes in the motor
2 Suggested Answers
  • 298 Answers
SOURCE: how to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Posted on Dec 21, 2010
Is there a fuse or a reset button on a Ryobi 10 inch surface planer. My planer stopped working after getting too hot. Now, it won't even trn on....
check the motor for a thermal over load button
to stop it over heating take more lighter cuts as the motor is a small motor compared to what the cut can be
May 09, 2016 | Ryobi Planer. 15 Amp 13 in. Planer AP1301
I have my ryobi planer completely apart to replace bearings but cannot get the housing off of the armature. Do I need to remove the brush holder? How? Any suggestions.
Well, you've probably already done it but make sure you HAVE removed the motor brushes. Usually hidden under a couple of plastic plugs that unscrew. That releases the commutator. The motor should then slide out. Depending on exactly which Ryobi planer you have be aware that sometimes there's a sticker on the end of the motor that actually hides a circlip or other holding device. Good luck!
Feb 24, 2015 | Tools & Hardware - Others
How to fit bosch PHO 15-82 planer base plate
my 15-82 has only one blade.There is a plate with three allen bolts to undo.Under that are two more allen key bolts to to undo.The blade moves although these two bolts are tight.The plane when looking at the drum has 6 inline holes.
Dec 17, 2012 | Bosch Tools & Hardware - Others
My Bosch 18V planer 53518 just stopped working. Worked fine one day, picked it up the next day, nothing!! Batteries fine, checked belts, etc. I see no problem. Any suggestions?
Did you ever figure this out? Mine just did the same thing. Fresh battery. Pulled trigger. Started to run, then just stopped. Don't know if it's the switch, motor or something else.
Oct 28, 2011 | Bosch 18V Cordless Planer 53518
How to fit bosch PHO 15-82 planer blades
Sep 16, 2009 | Bosch Tools & Hardware - Others
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Changing the brushes when the motor is off
Remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes, if they are any shorter than 1 cm replace brushes.
Nov 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washer carbon brush replacement
Remove rear panel, remove drive belt.
Unplug motor lead, undo 2 screws securing motor.
Lever back motor with screwdriver, remove motor..Carbons at opp end to motor pulley, remove and replace same.
Aug 27, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Tools & Hardware - Others Logo
136 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
