Question about Kitchen Appliances - Others
Brita faucet filter will not stay on faucet
I bought a FF-100 faucet filter. Using the adapter for inside threads I try to screw on the FF-100 and at first it seems like it fits snug with no leaks. But after a while it will just fall off if lightly touched. The adapter seems to fit my faucet. the actual ff-100  it just won't stay on very long. Its almost like there is just not enough thread sticking out of the faucet to screw it on completely although at times it does seem like its snug and may hold for a few hours.  Any suggestions
  • squijums Jan 27, 2009
    I don't use an adapter but mine does the same thing. Some of my roommates touch it and it falls off.
Want a free adapter and patient enough to wait for a couple of weeks to get them?
"To receive a special adapter free of charge, call 1-800-24-BRITA or 1-800-387-6940 (CANADA)."
Call the number above and a voice prompt will give you instructions on how to get your adapter for free. 2 weeks might be too long but the best thing is it is made of stainless steel/chrome and it comes in 3 different kind of adapters with rubber washers.
Posted on Apr 08, 2010
I had the same problem and struggled with various solutions including silicone glue and removing the screen. Silicone glue doesn't really hold and I believe the screen is needed to aerate the water prior to filtration.
At any rate, I finally fixed this by going to Home Depot and buying a METAL adapter as opposed to the provided plastic one.
"Bubble-Stream" Faucet Adaptor
15/16" x 55/64" -27 [It looks EXACTLY like the plastic one provided only its metal] for $3.86
and an assorted O ring package
Danco Stem Repair Part #80384 for $0.78
So under 5 bucks with tax out the door.
Threw the plastic adapter out the window, put the washer and new metal one on the faucet.
Cut and pulled apart the screen/white washer in order to get to just the screen.
Put the Danco flat washer collar in the Brita
Then the screen
Then a Danco O ring washer on top.
Screwed in the Brita.
Very slight, livable dribble on fitting, but the system is fully function and stays on now.
Thinking of putting some silicone glue on the Brita threads to fix the dribble at some point in the future but for now I'm satisfied.
Hope this helps
Posted on Feb 12, 2009
  • 1 more comment
  • ElemWiz Sep 26, 2010
    I just have to say THANK YOU! I ended up just needing the adaptor you mentioned, and it now works perfectly, without even a drip!
  • arnshea
    arnshea Aug 01, 2012
    You are awesome. Thank you so much! Brita is all out of their custom adapters - they're on backorder. I thought I'd have to buy water bottles for weeks!
  • arnshea
    arnshea Nov 06, 2012
    turns out this didn't work for me. It wasn't long enough. Had to wait for the one from Brita.
I also had this problem where my Brita on tap filter would fall off with the slightest touch. With our faucet, no adapter was needed. As others have mentioned, the problem is that with the white washer/mesh dome assembly in place, there is not enough additional threading to secure the unit to the faucet under pressure.
My solution was to do the following:
1) Remove the white washer/ mesh dome assmebly and pry the washer away from the mesh...keep the mesh.
2) Go to Lowes, Ace, or any hardware store and get some teflon valve packing string, like this from Lowes - http://preview.tinyurl.com/27g55pu. I had some on hand after repairing an outdoor spigot. This stuff compresses a great deal and forms an amazing seal.
3) Lay the teflon string inside the water filter where the old washer was. Mark where it overlaps and cut it. Sort of pack it in and flatten it out a bit with a flathead screwdriver, especially where it overlaps.
4) Place the mesh dome on top of your new, low profile washer. Wrap some regular teflon tape around the threads of your faucet and re-attach the filter.
That should do it. The teflon washer will compress far more than the original rubber one, allowing more thread to grab onto the faucet and creating a rock solid connection. The teflon tap on the faucet will prevent any leakage that might occur at the point where your make-shift washer overlaps.
Hope this helps someone out! Thanks...
Posted on Aug 16, 2010
Before I address the issue, here was what I experienced: (1) there is not enough threading on the adapter (2) the whole thing was leaking. My solution: I went to the hardware store and bought a metal adapter. I used the rubber washer that came with the Brita adapter AND I used a 2nd rubber washer (the one that was originally on my faucet). One rubber washer fits in with the metal adapter just like it fitted the plastic adapter. I stack the 2nd rubber washer above the 1st one (NOTE - just stack it. DO NOT try to stuff the 2nd ring into the adapter). Insert the 2 rubber rings/adapter assembly into the faucet head, then screw the adapter in. With the 2nd rubber ring, you have now made available more threading for the Brita to attach to. And you have reinforced the faucet from leakage. Now, screw on the Brita. Voila! No leaking, no fly-away Brita, no additional tape, no glue, no wire.
Posted on Aug 30, 2009
Here's a little hack that worked for me:
I noticed that the aerator/washer that comes with the filter was blocking the adapter from going far enough in for the threads to really take hold. So, I removed the aerator from the filter connection and moved it to where the black washer is supposed to go on the adapter (i.e., the dome-shaped aerator ends up in the faucet head when you screw in the adapter). I also wrapped thread tape (teflon tape) around the filter-end of the adapter to create the seal that would have otherwise been taken care of by the washer attached to the aerator. I needed to layer the tape on rather thick, but it seemed to work pretty well. No leakage/dripping so far!
Of course, I only did this because I had thread tape on hand...if you have to go to the hardware store anyway, it might make more sense to just get a metal replacement adapter (or have Brita send one to you for free if you're patient enough).
Posted on Jul 08, 2009
As Bryan Coolit mentioned in Solution 2, you can get a stainless steel adapters from Brita for free. I called and talked to someone instead of going through the voice prompts and I don't know if that made a difference, but it only took about 4 days for me to get the adapters. The adapter I used works very well and the faucet filter doesn't fall off anymore. I suggest calling them!
Posted on May 29, 2011
  • bachdog May 29, 2011
    Sorry about my poor grammar..oops. ;-) I was starting to say you get "a" stainless steel adapter but then changed it to plural without correcting the sentence. Let me clarify. You get 3 stainless steel adapters, but you will of course only need one. The improvement that the adapter supplies is additional clearance for the threads of the adapter to go deeper into the threads of the faucet filter before the turning nut hits a stopping point (a flange in the case of the adapter, the sink faucet in the case without the adapter); therefore, more threads of faucet filter are engaged and greater holding strength is provided.
Brita's replacement adapter is backordered for many weeks.
Home Depot-Neoperl faucet adapter 571493
easy on, no leaks, frustration and getting soaked everytime the Brita fell off is OVER!!!
Posted on Sep 21, 2012
True, using the 'new' plastic adapter is unreliable. it may work for some models of faucets, but not for others. if you bought a replacement, and you have the old metal adapter, use that one. clean it up with vinegar to remove the calcium deposits use the new wire mesh filter and rubber gaskets and install. it works fine.
Posted on Feb 11, 2011
Not a solution, but more info
I got a new Brita that will not stay on. It will not stay on the faucet that used to work with our old Brita, and it will not stay on the adaptor that Brita sent out. The threads on teh new one seem to be rounded in comparison with the old threads, and I measured the inside of the collar on the Brita, the old one is 82 hundredths o fan inch wide, but the new one is 83 hundredths. Somehow it's made differently and that is why it won't fit and we are trying all these ways to make it work!!
Posted on Jan 26, 2010
Today I bought a Brita FF-100 Black & Crome model. There was no green light flash after I inserted the cartridge. I don't if it's safe drinking or not.
This type of unit may have a battery that has a plastic tab that has to be pulled out so the battery makes contact. Did you read the instructions?
Brita FF 100 Google Search
Nov 24, 2016 | Office Equipment & Supplies
Brita faucet filter adapter is stuck in my faucet
It sounds like the adapter was screwed in at an angle. This causes the threads to cross in turn making it near impossible to unscrew. Since it is plastic I recommend buying a new adapter. I know it's unfortunate, however it is a lost cause.
Jan 23, 2014 | Clorox Brita Water Filter For Faucet White
Maytag Portable Dishwasher coupler/faucet problem
Standard garden hose has same threads/adapter size.for trouble shooting run garden hose to washer try running cycle. Give it 20 minutes to finish previous cycle as it may not be trying to run what appears on settings. Water won't fill unless cycle that will allow such is chosen and active.
Dec 01, 2013 | Dishwashers
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
Water flow is too powerful..
I got you, you want a screen to be put on the spout!
check the inside of the spout. there may be a internal thread, if it is, then you can get a external thread screen from home depot.
Apr 22, 2009 | Danze D405046 Bellefleur Single Handle...
Indicator light for Brita filter not working
I see this alot when I do installs...contact the Brita tech support
1-800-24-BRITA (US)
Jan 30, 2009 | Plumbing
He center piece of kitchen faucet (where hot/cold water comes out, has popped up off it's base
Iam assuming you are refeerring to the aerator which is a small round object with small screens inside of it through which the water runs. It mixes air into the water to give it a more uniform and controlled flow pattern as well as filtering out some debris. If this is the case than you could do the job yourself as long as thee threads are still good internally and externally. The piece screws into the bottom of the spout and the the threads it screws into are internal and therefore are not visible while the faucet is attached unless one is a contortionist. The threads usually are fine and sill usually screw in with little effort. If you encounter a bit of resistance you may be cross threading it. Just back it off and try again. It is a very doable task. Thanks for using Fix Ya and I hope I have been of assistance. If you need further help please let me know.
Jim
Oct 22, 2008 | Plumbing
Kitchen Appliances - Others Logo
15,126 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
