ACER Aspire M5620 won't boot from usb - Computers & Internet
  • 20 Answers
SOURCE: acer laptop aspire 5100 keyboard,all 3 USB ports,
Here are some great source where will will get any kinds of HP,ACER,DELL and COMPAQ laptop Solution and any kinds of Driver download.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
jakauiay37
Posted on Jan 03, 2010
  • 122 Answers
SOURCE: acer won't boot
Just go to the acer website and http://support.acer-euro.com/drivers/notebook/as_one_150.html and d/load the bios update 3309, open the folder and copy two files to a formatted fat usb stick. Rename the file FLASHIT to FLASHIT.EXE and the second file 3309.fd(bios file) to ZG5IA32.FD rename them precisely like that, please check your spelling is correct. Insert the usb stick into the usb left hand side make sure the charger is plugged in . Hold down keys fn+esc and power up the laptop, when the power led begins to blink release the two buttons and press the power button just once, observe the usb stick flashing indicating it's flashing the bios, please note this can take a few attempts, I once struggled for a few hours until I finally tamed the beast :) be patient okay, I would like to point out if you wish to update within winxp use the same bios update 3309 , extract the zipped files to a formatted usb stick and rename the two files again but DO NOT REMOVE or interfere with the other files in the folder , with the laptop up and running open the folder and click on the Insysdeflash file only within the winflash file, this will flash your bios within windows and update it to the latest version, I read that flashing it when using the fn+esc keys merely restores the bios , I have tested this and mine updated to 3309 only when I flashed my bios within windows using the complete d/loaded bios update as mentioned . It will be worth reading the read me file to see what has changed in this bios version, I can tell you that for those out there that have password issues i.e. hdd set, the need to enter password with upper case is not a requirement more and there are a lot more fixes too, enjoy and I hope this bit of info was useful:)
Posted on Jun 16, 2011
  • 106 Answers
SOURCE: We spilled water on top of the keyboard of an acer
I'm sorry to tell you but water can be vary damaging to your laptop. When its spilled on electronics while running it can cause shorts and they can permanently damage your laptop beyond repair. But Thats only a worse case scenario, your laptop may still be able to be repaired.
The first thing you should do is immediately remove the battery and unplug the laptop from the ac adapter to avoid further damage, Then try to get as much of the excess water out as you can, you could turn it upside down on a towel. If you have dry rice or a desiccant(Its a chemical used to **** up moisture) and a seal able container your could submerge it in either to help dry up the water as fast a possible.
The next step would be to take it to a local repair shop asap, avoid geek squad and the like, as there likely to cost as much as a new laptop. I would find a local shop and ask them how mush it would cost for them to dry it out and test it. If you cant afford to have it fixed at a shop or the amount of water was minimal, you can try to leave in the container for a few day and hope for the best next time you start it. I've save quite a few soaked electronics this way.
I hope I could Help.
Posted on Jun 21, 2011
virtual_a
  • 531 Answers
SOURCE: my acer aspire 5551 laptop isn't starting up its
Hi
Check underneath and use a small screwdriver to open the small rectangular panel with the image of a stack of CDs near it. This is where the Hard Drive sits.
Check to see if the Hard Drive is properly fitted properly docked into its socket and screwed down or held down properly so it is immobile during use.
If this is not the problem, tap the Fn + the correct function key to enter the Boot Menu at Start Up and use the keyboard arrows to select the Hard Drive boot option.
Make sure there is no CD or DVD in the Optical Drive.
If none of these is the problem then, regrettably, your hard drive may have failed, so remove it and test it in a hard drive dock or an external 2.5" Hard Drive Enclosure.
If it has failed you will obviously need a new hard drive, bootable operating system disc, drivers disc and programs and security software to reinstall everything to the new hard drive.
Unfortunately, any data on the old drive will be lost.
It is very unusual for a Hard Drive to fail suddenly without some prior warning or signs of failing (the only realistic way would probably be through a drop, severe knock, serious mains power surge or mains power cut, incorrect shutdown procedure, or sudden disconnection of the power cable during use).
Back up regularly to an external storage device and do not ignore any warning signs. Also plug all computer equipment to the mains via a Surge Protector/Suppressor to prevent damage from power surges or fluctuations.
I hope this helps
Posted on Aug 27, 2011
luis_david
  • 407 Answers
SOURCE: ACER ASPIRE ONE D255E POWER CORD WON'T CHARGE
Hi: Acer chargers have a very short life time, in the past 2 years I had bought 2. Just buy a new one from amazon they're very inexpensive. Here's the link: http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Posted on Sep 25, 2011
Why won't the hard drive activate on my acer aspire one 522, the bios can see it.
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time. http://www.fixya.com/support/r4482455-repair_windows_xp
Apr 05, 2013 | Computers & Internet
My acer aspire 7735z turns on but won't boot up
your hard disk maybe corrupt.
The operating system is in the hard drive, so if it won't boot, your OS might need to be repaired or reinstalled.
You will be needing OS CD to carry out the re installation
Good luck.
Nov 28, 2012 | Acer Aspire 7735z 17.3" Laptop Original...
My acer aspire 5349 Won't Boot at all.
when you boot go into your bios settings and check in your boot section to make sure your hard drive is there and enabled. set it to first in boot order.
Nov 26, 2012 | Acer Aspire 9300-5349 Notebook
How to format a notebook that doesn't have a cd drive
You'll have to buy a external Drive. Then you can boot using a OS CD or DVD
That's it Pretty Much
Good Luck
Oct 20, 2011 | Acer Aspire One PC Notebook
My acer aspire 2920 goes black screen when I try to boot Ubuntu from USB. I thinking of reset the bios. Please help me with the procedures
Hi there. It won't be a bios problem if it allows you to selet the usb to boot from. Sometimes when you try to boot ubuntu off of a usb it gives you a black screen for as long as 2+ minutes. usb drives can be slow but if it still will not boot then it is likely a problem with the boot loader on the usb stick. I would try installing ubuntu to the usb again to see if it works. If it still won't work then there is more than one way to install ubuntu to a usb. Leave a comnent here if you still can't get it to work and i can give you some more instructions of how to make it work. It shouldn't be a problem with your computer though.
Sep 14, 2011 | Acer Aspire 9300 Notebook
My Acer Aspire One Nav50 won't boot. I hear there
I have a Acer Aspire One ao532h (NAV50) a with a black out screen new screen and flax cable it came on for 3 mins and the now not a thing what should I do ?
Aug 02, 2011 | Acer Aspire One 10.1" Netbook Computer -...
Acer aspire m5620 freezes, no mouse, monitor shows image but interacion. hard drive activity - none. must hard boot.
Hi..
Restart your PC and keep tapping F8.. choose startup repair and let it diagnose and fix --
Hope this helps !!
Sep 07, 2009 | Computers & Internet
Computers & Internet Logo
207 people viewed this question
David Payne
David Payne
